Turn signal help please - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 31st, 13, 06:26 PM Thread Starter
Tommy
Hey guys needing some help. All of my lights work properly except for the right front turn signal.
I can take a power probe and inject 12 volts into the harness that goes down to the light (brown / blue wires) and I can force the parking lamp and turn signal lamp illuminate like they should. So they tells me bulb connections and grounds are good to that point.
But when I get to the fire wall I am not sure we're the next point should be to inject the 12 volts again to see if I can find where it's open at.
I assume with the right rear working the turn signal switch at the column is working properly.
So I guess question is does anyone have a good test point inside the car between the firewall and the column?
69 Z28 X77
zfuzz is offline
post #2 of 6 (permalink) Old Mar 31st, 13, 06:42 PM
69-Pace's Avatar
Re: Turn signal help please
could be a few things such as the turn signal switch, hazard light switch, brake light switch as they are all inter connected. Does the light light as parking? Does the light flash with hazards and if yes, does it stop flashing and stay lighted when you hit the brakes?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 6 (permalink) Old Mar 31st, 13, 06:45 PM
You should be able get to the same color of wires on the steering column connector.
Turn signal indicator in the inst cluster is tied into firewall connector for rt front.
post #4 of 6 (permalink) Old Mar 31st, 13, 08:22 PM
George
Gbauer's Avatar
Try replacing the light bulb in the dash.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #5 of 6 (permalink) Old Apr 1st, 13, 05:21 PM Thread Starter
Tommy
Thanks guys for the tips, I found the dark blue wire on the column and verified the turn signal switch was working. So from there started working my way back toward the firewall.
Found that I have switch connectivity to the blue wire right before it goes into the fuse block but nothing on the engine bay side of the fuse block connector.
So before I take the block apart is there a trick to getting it back together? The bolt on the engine bay side looks like its going to be a bear to get back in due to the power brake booster.
69 Z28 X77
zfuzz is offline
post #6 of 6 (permalink) Old Apr 5th, 13, 05:25 AM
69-Pace's Avatar
Yeah it is a rough place but you can do it with everything in place. I have seen guys with thicker builds take either the booster or the fender off. I would try to avoid that.
69-Pace is offline
