msd ready to run/blaster ss - no start?? - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 17th, 13, 07:52 PM Thread Starter
hey guys i have a 69 camaro small block, it had a gm hei that ran ok, but it was too big and was smacking the firewall a bit.
i have replaced the hei with an MSD ready to run #8320 small block chevy distributor, i have used an external coil MSD blaster ss. i replaced both of the springs with the 2 lightest silver springs (as a reccomendation of my engine builder)
i hooked everything up (12v old hei power into the new MSD distributor).
i set the timing locked the dizzy down and the car ran great, i took it on a 20 minute drive, no issues at all.
then i parked it for 2 hours when back to start, no start. no spark at all??
i tested the coil and distributor are both getting full power. i took out one of the spark plugs and tried to fire and no spark at all coming from the plug.
i then tested the coil based on a test that MSD reccommends "You can check the primary resistance (plus to minus) .355 ohms and secondary (plus to center tower) is 4.4K ohms. This is a resistance test and with out a load bank the only test you can do."
SOURCE: http://www.msdignition.com/forum/showthread.php?t=8591
the coil pasted this test above with no isue.
what do you guys reccommend? it looks like to me a bad coil?? but after only 20 min run time??? wow.
at first i thought it was because i mounted the coil upside down, but supposedly the blaster ss coil can be mounted in ANY orientation. unlike the blaster 2 coils which have to be mounted vertically.
i took the cap off and cranked the motor, the distributor rotor IS turning.
any reccommendation on what to troubleshoot next??
thanks guys.
m21man is offline
post #2 of 10 (permalink) Old Apr 17th, 13, 08:10 PM
Vega$69's Avatar
Re: msd ready to run/blaster ss - no start??
Do you have an #8360?
Probably a bad coil. Even though the primary test good the secondary could be bad.
I would try another one
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 10 (permalink) Old Apr 17th, 13, 08:22 PM Thread Starter
Yea sorry the distributor is MSD #8360.
i will try to put in another coil tommorow. Although I cant believe it would fail after only 5 minutes of run time? wow.
m21man is offline
post #4 of 10 (permalink) Old Apr 17th, 13, 08:41 PM
Vega$69's Avatar
Runs one time. Heats up cools off shorts out. Happens sometimes
Good luck with fix
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #5 of 10 (permalink) Old Apr 18th, 13, 04:49 AM
Move the coil, it is right above the header tube, heat rises.
Place the coil where OE design has it.
post #6 of 10 (permalink) Old Apr 18th, 13, 05:53 AM
Steiner
Check and see if the old HEI wire you are using for power is run directly to the ignition spade on the fuse block in the car, or if it's connected to the old cloth covered resistor wire at the firewall. The new modules do not function well if they don't get a good 12V.
Also, I felt like the resistance of that coil was too low as it's specifically made for ignitions that have current limiting capability. MSD's application guide and instructions are kinda sketchy so I went with the epoxy filled Blaster canister coil and haven't had any problems.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 10 (permalink) Old Apr 18th, 13, 09:54 AM Thread Starter
guys i replaced the coil, no start.
i exchanged the distributor for a new one at my local pep boys, the thing fired right up. these msd unit are crappy quality control. when i opened up the new unit there were small metal shavings everywhere unbelievable.
m21man is offline
post #8 of 10 (permalink) Old Apr 18th, 13, 02:46 PM
Steps
Put the GM hei back in, and replace the trans mount with the high mount... check how the fan sits in the shroud...it should just clear the bottom by about 5mm
MSD ready to run
This is massive propaganda marketing BS... there is no such thing...it is imposible to drop a random dizzie and have the correct advance at a given rpm and engine load for a given engine so the max explosion, (cylinder pressure) occures at a given piont for THAT engine between 12 and 18 deg ATDC +/- 2deg max.
Then throw in bore to stroke, compression , cam profile and fuel type as variations in timing...
Add to all that HEIs off the shelf are pre curved general ball park for EGR / pollution engines running very lean cruise ...
Further more, check out the current and recent threads on MSD ign..
And add to that multi spark is only for those who dont keep their ign system, leads, plugs etc in top condition, and only works at low rpms..
plus 3 colours in an engine bay is rule of thumb, a bloody ugly red box does nothing for looks other than bragging rights for when those not in the know are around.
PS I dumped an elcheapo GM type Chinese HEI in mine last yr, recurved etc, expecting to have no end of trouble.. knocked up around 8000 miles on it.
This is NOT one of the countfeit MSD units they mention on the MSD web site.
Only issue was a pin hole in the back of my water pump yesterday as I pulled into the workshop at morning tea...closest issue had... so far.
Steptoe is offline
post #9 of 10 (permalink) Old Apr 18th, 13, 03:29 PM Thread Starter
the thing runs great now. but im forecasting some issues in the future as i dont trust chinese crap haha. the only reason why i went MSD is because the engine builder that built the motor dyno's them with these MSD units and they know exactly what springs/bushing to put in etc...
i will keep the GM hei in my trunk just in case!
thanks for all the help trouble shooting guys!
m21man is offline
post #10 of 10 (permalink) Old Apr 19th, 13, 12:12 AM
Steps
Nore do I.. I needed a unit quick.. just suprised how it is doing as wore the HEI out.
But do keep hew orginal working pionts dizzie around as a spare
Steptoe is offline
