Tails & Turns Question - Team Camaro Tech
post #1 of 3 (permalink) Old May 6th, 13, 08:40 AM Thread Starter
Justin
So, this is a real newb question but I have searched and cannot find the answer. Im building a custom harness for my car as Im doing a lot of custom stuff and have a question regarding how the tails and turns work on a 67 RS. There is a dim setting for all of the bulbs which I am assuming is for running lights, and then a bright setting for each bulb which I am assuming are used for brakes and turns. Im also assuming that two of the lights function as brake lights and the other function as turns? Also, which lights are the turns and which ones are the tails?
Butters - 67 Restomod RS Butternut/Black, 5.3LS w/ worked heads & TR220cam, AR-5 trans, 8.2 posi w/ 3.36 & multi-leafs, tubular arms, 4 wheel discs, 1.5 drop, Cal-Trac clones, Rally 1000s w/ bench, DSE SCs, DD VHXs, Projector fronts & LED rears.
JPalmer is offline
post #2 of 3 (permalink) Old May 6th, 13, 11:24 AM
Re: Tails & Turns Question
On an XX57 bulb, 1157, 2057, or 3057, the upper element is the brake/turn/hazard illumination.
The lower filament is tail/parking light only.
A the turn signal switch, there are three different power inputs, and only one output per side.
Hazards, brakes, and turn signals.
post #3 of 3 (permalink) Old May 6th, 13, 02:35 PM Thread Starter
Justin
Gotcha, thanks Everett.
JPalmer is offline
