Heater switch wiring - Team Camaro Tech
post #1 of 2 (permalink) Old May 6th, 13, 09:22 PM Thread Starter
I just got this 1969 Camaro the heater fuse was missing I checked the right side of the fuse holder and there was power I checked the left side and there was no power. When I turned on the fan switch the left side also had power, is it normal to have power on both sides of the fuse holder at the same time. When I put a 30 amp ( I didn't have a 25) nothing worked and the fuse didn't blow. I am also looking for a control lever and knob for this heater/ AC switch any suggestions where to look?
ssi.john is offline
post #2 of 2 (permalink) Old May 7th, 13, 04:05 AM
69-Pace's Avatar
Re: Heater switch wiring
Power should flow through the fuse from one side to the other. Electricity flows like water, and in these cars from positive at the fuse block through the fuse to a grounded object such as a switch housing, or light bulb socket etc.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
