Power supply for DSE wiper motor - Team Camaro Tech
post #1 of 4 (permalink) Old May 12th, 13, 12:50 PM Thread Starter
chuck
chucky 67's Avatar
Just wiring up my DSE wiper motor on my 67 and trying to figure out where to connect the switched power supply wire. It comes with a 30 amp in line fuse on a 12 GA. wire and it needs to be connected to a switched power supply. DSE says it needs to be 30 Amp. Is 12 GA.wire to small for a 30 amp fuse? And where would be a good source for a 30 amp switched supply Thanks.
1967 camaro LS3 TKO 5 speed A.C. delux Int.
chucky 67 is offline
post #2 of 4 (permalink) Old May 12th, 13, 06:30 PM
Robert
ROBS6T8's Avatar
Re: Power supply for DSE wiper motor
So you can't run it to your existing wiper wires? I have a Painless fuse block and have no idea what's available on a stock fuse block.
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread
ROBS6T8 is offline
post #3 of 4 (permalink) Old May 12th, 13, 06:45 PM
Bob
Something seems odd-12 gauge wire is only good for 20 amps, so with a 30a fuse, you'll fry the wiring before you pop the fuse if it really draws 30 amps. Sure it's not a 10 gauge wire?
BobKovacs is offline
post #4 of 4 (permalink) Old May 12th, 13, 07:22 PM Thread Starter
chuck
chucky 67's Avatar
Its defiantly 12 GA. they even call it that in the instructions. I asked DSE about using a 20 or 25 amp keyed power and they said to use 30. The original wiper fuse is a 20 and the heater fuse is a 25, I could try one of those. I have Vintage Air and don't need those spots and that would be sized better for the 12 GA wire.
