Remove MSD ignition box - Team Camaro Tech
post #1 of 17 (permalink) Old May 12th, 13, 06:10 PM Thread Starter
Mikael
Hi,
I have a MSD 6A ignition in my -67 Camaro. It has a 327ci/210HP engine modified with an Edelbrock Performer intake, 4-bbl Rochester QuadraJet, Hooker headers and a 2.5" Magnaflow exhaust system as the only modifications as far as I know.
Have read that a MSD ignition is not needed on an almost standard engine and that it probably is a source for future problems.
Can I remove the MSD box and just run it as a non-point ignition?
Do I have to swap the distributor?
Do I have to buy a electronic ignition kit?
Also, what brand of distributor do I have?
Well, a lot of questions from a newbie...
Have added some pics below of the MSD parts in the car.
Rgds/Mikael
69 Chevelle Malibu 400/TH400 (136379Z328013)
67 Camaro Coupe 327 - Sold 26:th of Aug 2014
Elmer is offline
post #2 of 17 (permalink) Old May 12th, 13, 06:51 PM
Bob
Re: Remove MSD ignition box
Judging by the MSD rotor, I'd say you've got an MSD electronic distributor, so you need the box to control it. I don't see any reason that you'd have issues with the MSD setup on a stock engine- it's not a necessity, but it shouldn't hurt anything. Is it running OK for you?
BobKovacs is offline
post #3 of 17 (permalink) Old May 12th, 13, 07:05 PM
Tony
Mikael,
You have an MSD distributor, as seen by the magnetic pick-up and reluctor wheel below the rotor. You do need to run the MSD 6a with this distributor and although it is not required for your engine it certainly won't hurt. It will give you easier starts, cleaner burning of the fuel as long as you maintain the tune-up/carb tuning. I have been running the same distributor and an MSD 6AL for over 15years without trouble.
Tony:
67 RS Clone, 388 SBC/Keisler TKO 600/12 bolt, 3.90 gear w/posi and a 250 shot of N2O for fun. See my progress at: password is camaro
idoxlr8 is offline
post #4 of 17 (permalink) Old May 13th, 13, 02:16 PM Thread Starter
Mikael
Have had problems with backfiring but it was the ignition cables. When replaced it runs without problems. I was just thinking of removing the MSD box because I have read that they are famous for causing a lot of trouble.
Elmer is offline
post #5 of 17 (permalink) Old May 13th, 13, 02:18 PM Thread Starter
Mikael
I will keep on using the MSD box since it is not causing me any problems.
Elmer is offline
post #6 of 17 (permalink) Old May 13th, 13, 02:20 PM Thread Starter
Mikael
Bob and Tony,
Thanks for the information of what distributor I have. Might be good to know at some point.
Rgds/Mikael
Elmer is offline
post #7 of 17 (permalink) Old May 13th, 13, 05:16 PM
Steiner
Have MSD run the serial number for you and see how old it is. The older it is, the better it probably is given their recent track record. I've got an old 6A that's been on my supercharged S10 for about ten years that's never had a problem.
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 17 (permalink) Old May 15th, 13, 03:13 PM Thread Starter
Mikael
Thx. Will try that.
Elmer is offline
post #9 of 17 (permalink) Old May 17th, 13, 08:47 AM
Robert
ROBS6T8's Avatar
Totally agree!
68 Camaro SS... getting there!!
"If happiness is in your destiny, you need not be in a hurry."
If I can only convince myself of this!
My slooow build thread
ROBS6T8 is offline
post #10 of 17 (permalink) Old May 17th, 13, 09:04 AM
Greg
I have been running and MSD 6A with an HEI with a supercoil and my car recently began starting hard. I am reworking my wiring harness and to clean things up in the engine compartment I decided to remove the MSD and just go with the HEI and supercoil. Now it starts immediately, kind of weird.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #11 of 17 (permalink) Old May 17th, 13, 02:50 PM
Ran the 6al for over 10 years and no issues....now in a buddies 79 Vette.
68 Camaro~LSx ~all motor
post #12 of 17 (permalink) Old May 18th, 13, 12:22 AM
Larry
larryh56's Avatar
Depending on the MSD distributor you have you may not need the box. The "ready-to-run" units like the 8360 don't need one but some people use them. I have the 8360 and it looks just like that.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #13 of 17 (permalink) Old Jul 17th, 13, 11:51 AM Thread Starter
Mikael
Once again I will thank you all for the answers.
Since I am born as curious guy I wonder how I can check what MSD distributor it is?
Do I have to remove it?
I guess I should be able to find a number or something somewhere. Have looked from all angles when the distributor is in the car but have not seen any kind of numbers...
Rgds/Mikael
Elmer is offline
post #14 of 17 (permalink) Old Jul 17th, 13, 01:46 PM
Matt
It looks like you have MSD model number 8361 distributor. You need an MSD ignition box in order to run that distributor. If you remove your ignition box, the car will not run with that distributor because it does not have its own ignition module in it, only a magnetic pickup which signals the box when to fire. You only have a two wire plug coming out of the distributor,that is what gets connected to the box.Hope this helps.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #15 of 17 (permalink) Old Jul 17th, 13, 02:30 PM
Michael
If you are having problems with your wires, make sure you ARE NOT running graphite or solid core. USE ONLY spiral wound wires.
mahunt is offline
Tags
ignition, msd
