Fused accessory wire? - Team Camaro Tech
post #1 of 3 (permalink) Old May 12th, 13, 06:45 PM Thread Starter
Matt
I was finishing up a simple project and bumped a wrench on the horn relay. I heard a quick pop at the relay, but also over near the battery. Now I have no power to dome light, headlights, ignition, etc. I assume there is an in-line fuse somewhere that powers the fuseblock, but don't see it. Can anyone tell me what popped by the battery and how to find it? Or, if there is something else I burned, let me know what it might be. Thanks
srq34231 is offline
post #2 of 3 (permalink) Old May 12th, 13, 06:47 PM
Bob
Re: Fused accessory wire?
There's a fusible link near the battery, usually tied to the little junction block/screw on the radiator support behind the battery if I remember right.
BobKovacs is offline
post #3 of 3 (permalink) Old May 12th, 13, 06:49 PM
69-Pace's Avatar
Sounds like you dead shorted the main feed and cooked a fusible link. Look for discolored links by the main junction block behind the battery and the horn relay.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
