Press brake the turn signals go on - Team Camaro Tech
post #1 of 8 (permalink) Old May 30th, 13, 07:05 AM Thread Starter
Bob
MileHigh69's Avatar
I am putting my car back together after getting my car returned from Auto body jail. When I press the brake pedal both turn signal lights go on and stay on. Any ideas?
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #2 of 8 (permalink) Old May 30th, 13, 07:21 AM
Re: Press brake the turn signals go on
Turn signal indicators?
If indicators are coming on, are the front bulbs coming on?
Jiggle the turn sig lever, blow off the body shop dust, and most important, ensure the cluster ground is in good shape, meaning unscrew & screw the screws.
post #3 of 8 (permalink) Old May 30th, 13, 07:38 AM Thread Starter
Bob
MileHigh69's Avatar
Yes turn signals. My front lower lights are not in yet. Would this cause the problem?
post #4 of 8 (permalink) Old May 30th, 13, 10:40 AM
Yes, it may. Not saying it would, but, doesn't hurt to try.
post #5 of 8 (permalink) Old May 30th, 13, 11:23 AM
Jason
blue89bird's Avatar
I don't know if the lack of parking lamps is causing the issue with hitting the brake pedal causing them to light up, but I knwo for a fact that without them installed on my 68 it caused all sorts of issues electrically.
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #6 of 8 (permalink) Old May 30th, 13, 08:54 PM
Jeff
yellow69RS's Avatar
Check that the four way flasher button is not pressed in.
Jeff
yellow69RS is online now
post #7 of 8 (permalink) Old May 30th, 13, 09:38 PM
Lynn
Installing the wrong bulb will cause that as well.
Hook up all the lights before testing.
Make sure everything is grounded.
Check to see that you have dual filament bulbs in all the sockets that have two contacts.
Lynn
bilodeaulynn is offline
post #8 of 8 (permalink) Old May 31st, 13, 07:25 AM
Jeff
Betcha Jeff nailed it.
Jim & Yvonne
1968 Camaro
468 BBC, Turbo 400, 4.10 12 Bolt.
2010 Camaro SS/RS, Black on Black Leather
2008 GMC Crew Cab 4x4, LMM Duramax, Allison 6 Speed,
6" Cognito Lift, 35" Nitto's
Ledfoot is offline
