How many Amps - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 26th, 13, 05:28 PM Thread Starter
How many Amps
How man amps and volt does a blower motor pull ?
meusebi is offline
post #2 of 5 (permalink) Old Jun 26th, 13, 07:18 PM
Re: How many Amps
Fourteen volts, about 6-7 amps.
Twelve volts, about 7-8 amps.
post #3 of 5 (permalink) Old Jun 27th, 13, 05:10 AM Thread Starter
Re: How many Amps
Thank you mine is only pulling 2 amps so a least it is not pulling to much.
meusebi is offline
post #4 of 5 (permalink) Old Jun 27th, 13, 11:53 AM
Re: How many Amps
Startup current will always be higher, though I couldn't tell you what a normal number might be. Once the motor spins up it should run at a lower amperage. If the amperage is too low, be on the lookout for bad connections. Bad connections add resistance, reduce the current and dissipate your current as heat that only serves to melt connections and burn things.
dnult is offline
post #5 of 5 (permalink) Old Jun 29th, 13, 07:13 AM Thread Starter
Re: How many Amps
I was just testing it connected to the battery with a piece of wire it was out of the car it more than likely I did not have a good connection. I am completely rewiring the car and the plugs to heater were burnt out so I wanted to test the blower motor. I am going to change the switch on the controls and change on the harness and check again.
meusebi is offline
