Directionial signal harness - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 27th, 13, 06:59 AM Thread Starter
Marty
How big a job is it to install a new signal harness on a 68 with automatic floor shift? Brought the car to a guy and he said he's had to lower the steering column, and take out the dash and unhook the speedo???? Also said he had to cut some wires on the harness bought from a Camaro supplier.
Starting to have my doubts!
QbyMarty is offline
post #2 of 4 (permalink) Old Jun 27th, 13, 07:16 AM
Re: Directionial signal harness
I would think:
1. Unplug the column harnees,
2. Tie a string to the column harness,
3. Remove horn button/center piece and remove steering wheel - mark both the wheel and shaft for alignment, if not done yet,
3. Unscrew turn signal handle,
4. Unbolt turn signal switch,
5. Carefully pull up switch until removed from column - untie string,
6. Tie string to new harness,
7. Gently pull harness through column using string to guide harness through column,
8. Reverse order of Steps 1-4.
I have done this procedure for a combo switch and a VATS tumbler.
I could be hosed on the procedure.
post #3 of 4 (permalink) Old Jun 27th, 13, 08:03 AM
Jason
blue89bird's Avatar
it sounds like he doesn't really know what he's doing to be honest, it's not that hard of a job. Could have the column out of the car in 15 mins.
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #4 of 4 (permalink) Old Jun 27th, 13, 03:25 PM
Gordon
gordr's Avatar
Gotta watch out if it's an 8 pin or 9 pin harness. When I replaced mine in my 67 machine I had to add on an adapter from 9 pin to 8 pin.
Column does not have to come out, I remember lowering mine a bit for clearance.
67 Plain Jane being assembled with 427, 4 spd Muncie, 12 bolt rear with Mosers, 4 wheel discs
gordr is offline
