1969 Camaro Turn signal switch assembly - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 12th, 13, 06:16 AM Thread Starter
Jeff
Send a message via Yahoo to irethedo
I just took apart my steering column (non-tilting type) on my 69 to replace the ignition key lock and when I removed the 1969 Camaro Turn signal switch assembly, there was what looks like a narrow connector that maybe is supposed to connect to the back side of this switch with a thin copper strip?
The connector itself is broken but appears to have been a long thin clear plastic piece that plugged into the steering column casting in a square hole.
Does anyone know what this piece is for and have a picture of how it should be connected?
I am wondering if this supplies a ground for the horn that gets routed through to the top side of this switch.
I need to know what this copper strip is supposed to connect with on the switch and its purpose...
Any pictures or descriptions would be appreciated
thanks
irethedo is offline
post #2 of 6 (permalink) Old Jul 12th, 13, 06:54 AM
Guess
HwyStarJoe's Avatar
Re: 1969 Camaro Turn signal switch assembly
Sounds like the key buzzer switch. It's not uncommon for the tabs to break off. It doesn't really 'connect' to anything... it makes contact when the ignition lock cylinder is in the OFF position and buzzes the horn relay when the door is opened.
HwyStarJoe is offline
post #3 of 6 (permalink) Old Jul 12th, 13, 11:53 AM Thread Starter
Jeff
Thanks for the info- That looks like it.
Any idea what the copper tabs connect to?
irethedo is offline
post #4 of 6 (permalink) Old Jul 12th, 13, 03:08 PM
When ign key is installed and in the OFF or Locked position, open the drvr door and the horn relay buzzes its butt off until either the door is closed or key is removed.
Most people disable this function as it is almost the most annoying feature by pulling off the black/pink wire at the horn relay. But, it performs its designed purpose - annoy you to say you've left your key in the ign switch.
Everett#2390 is online now
post #5 of 6 (permalink) Old Jul 13th, 13, 08:57 PM Thread Starter
Jeff
So if I leave this piece out, then the only change will be no "key in ignition warning buzzer"?
I can live without that...
thanks
irethedo is offline
post #6 of 6 (permalink) Old Jul 13th, 13, 10:50 PM
Jeff
yellow69RS's Avatar
To answer the original question "what do the two strips connect to?" They touch two contacts on the back of the T/S switch to perform the function as Joe and Everett have said above. To the second Question Yes just no buzzer.
Jeff
yellow69RS is offline
