Horn not working - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 30th, 14, 05:02 PM Thread Starter
skeetc
Horn not working
Hi team camaro. I recentley rewired my 1968 camaro with painless performance wiring harness. I installed an internal regulated alternator. I have taken the steering wheel off. I put a test light on the horn cylinder in the steering column and get power. I put test light on the horn fuse in the fuse box and get power. When i push the cylinder in at the steering column should i have power on the green wire at the horn. When i do this i have no power at the horn. I took jumper wire from the battery and both horns work. I have tested the horn relay and it has power at the fuse box. Any help would be appreciated
goatmuscle is offline
post #2 of 4 (permalink) Old Jul 30th, 14, 05:05 PM
69-Pace's Avatar
Re: Horn not working
Do you hear the horn relay clicking when you ground the horn wire?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 4 (permalink) Old Jul 30th, 14, 05:36 PM Thread Starter
skeetc
Thank you. It is a new Grant steeringwheel. I was not getting good ground. I grounded the cylinder to the steering shaft and the horn works fine. Thank you for your help
post #4 of 4 (permalink) Old Jul 30th, 14, 05:46 PM
69-Pace's Avatar
69-Pace is offline
