wiring color code - Team Camaro Tech
post #1 of 11 (permalink) Old Jul 31st, 14, 09:34 AM Thread Starter
thefley
wiring color code
I am in the middle of changing out the gauges to Dakota Digital VTX with center console gauges so now I need to know what the color the original wires are that I will use to hook to DD module.. anyone have an easy to understand graph or a sheet to show what the colors were to where
someone had installed a horse shoe shifter and center console gauges but never wired them in. so I see 4 wires from the horse shoe shifter that go nowhere, can someone tell me where these go as well?
First Gen Camaro Connections on Facebook
thefley is offline
post #2 of 11 (permalink) Old Jul 31st, 14, 12:06 PM
Chris
130fe's Avatar
Re: wiring color code
Are you using the factory dash harness or aftermarket? Are you using the factory wires in engine compartment for the senders or the DD ones? I mounted the DD control box right behind where the speedo/tach go. I can post a couple of pics to show you what I did. BTW, I was the guy that posted pics up on Facebook for the shifter wiring.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #3 of 11 (permalink) Old Jul 31st, 14, 12:39 PM
Lyle
wires to the neutral safety switch on the shifter are as follows:
Pink power into backup lamp switch, Green switched power out to lamps.
Purple/White starter power from ignition switch to park/neutral switch, Purple to Starter.
I'm guessing that the cut off pair with one orange wire is for a lamp at the rear of a console.
1969 Camaro Convertible
thebat is offline
post #4 of 11 (permalink) Old Jul 31st, 14, 02:14 PM Thread Starter
thefley
Thanks guys. And thanks Chris I printed those pics off.
The plug that went into the back of old gauges will also be the wires and colors Ai will also need to know. Years ago I had seen a post describing what each one under dash was for. Not the complete car wiring harness diagram.
Any thing helps. I found 68 build manual online but didn't break it all down that far.
thefley is offline
post #5 of 11 (permalink) Old Jul 31st, 14, 02:15 PM
Chris
130fe's Avatar
Here is how I mounted mine (behind the steering wheel). I just used a sheetmetal screw to secure the bottom hole on control unit to the dash, Seems pretty secure.. I have the VHX with everything together, do the vhx console gauges connect with a CAT 5 wire between the control box and console gauges?
Chris
130fe is offline
post #6 of 11 (permalink) Old Jul 31st, 14, 03:03 PM
Chris
130fe's Avatar
Look at this one- http://www.americanautowire.com/PDFL...20IN%206.0.pdf Although it is for an AAW harness, the information for the wire colors are there. Good luck!
Chris
130fe is offline
post #7 of 11 (permalink) Old Jul 31st, 14, 05:53 PM Thread Starter
thefley
I noticed you have two wires going to the "ACC Power" OR is that the "TACH" that has both going to it on the module?, why 2 and what are they for or from?
or do they both sharing slot for tach? just hard to see on phone
yes the console gauges also connect to the module with cat 5
Thanks THefley
thefley is offline
post #8 of 11 (permalink) Old Jul 31st, 14, 05:55 PM Thread Starter
thefley
THANK YOU SO MUCH!!! this is what I needed!
thefley is offline
post #9 of 11 (permalink) Old Jul 31st, 14, 07:30 PM
Chris
130fe's Avatar
I am using 2 wires (pink and orange) in the the one slot, pink (from dash harness) for control module power and the other one- orange (I added that, not from dash harness) to power up the BIM module (it takes the readings off of my LS3 PCM (you probably don't have that). The BIM module (you can see it just right of the control module) takes the tach, oil pressure and water temp readings off of the PCM, pretty nice and less wires to run.
Chris
130fe is offline
post #10 of 11 (permalink) Old Jul 31st, 14, 07:59 PM Thread Starter
thefley
Thanks. I have a gray wire from my MSD Ignition running to tach on module. With center console gauges. About to post a couple more pics with guest on on wiring to module and wires I have left. Instructions confusing and no real directions on em.
thefley is offline
post #11 of 11 (permalink) Old Aug 1st, 14, 07:34 AM
Chris
130fe's Avatar
You might want to think about where you are going to mount the 2 function buttons. I ended up putting them just to the left of the dash carrier on the lower side of the metal dash. I did have to extend these button wires to reach the module. I will try and take a picture and post up later. Setting the gauges up took some time but was able to figure out after a couple of times trying. You have to set up each gauge (parameters, sending unit type, ext). I have not setup the warning limits of the gauges, another cool feature of the system.
Chris
130fe is offline
