Help with electric fuel pump - where do get signal??? - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 31st, 14, 06:56 PM Thread Starter
Cory
Where should I get the signal from to run my electric fuel pump? I am running a Holley F.P. to a Carb. I plan to run a relay but where do I get the signal to turn the pump on from? I read a few post that said to run it from an oil pressure switch? Is that the best way to do it? I guess I assumed you would just grab a key on power source and use that to run the pump. Is that not a good idea? Any help would be great. Don't assume I know anything cause . . . =) lol
Thanks, Arkangel77
Arkangel77 is offline
post #2 of 7 (permalink) Old Jul 31st, 14, 07:02 PM
jeff
1SLOW64's Avatar
Re: Help with electric fuel pump - where do get signal???
key on source is fine or a seperate toggle switch.
1969 X66 PROJECT:
2002 C5 COUPE ELECTRON BLUE SOLD
1987 BUICK GRAND NATIONAL SOLD
1964 CHEVY II 406 SOLD
1SLOW64 is offline
post #3 of 7 (permalink) Old Jul 31st, 14, 07:24 PM
Vega$69's Avatar
If I may ask?
Why electric pump?
If so you do not need a relay. I would run it off key switch
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 7 (permalink) Old Jul 31st, 14, 07:58 PM Thread Starter
Cory
I am going with an electric pump cause I am building a High performance motor/set up that will require more fuel than the stock system can provide. I am glad to here that a Key on source will work. Any advice as to what wire is best from the stock harness to tap onto? Thanks, Arkangel77
post #5 of 7 (permalink) Old Jul 31st, 14, 08:18 PM
Doug
Here are the directions from Summit racing fuel pump relay kit. http://www.jegs.com/i/JEGS+Performan...10564/10002/-1 Click on instructions. If it is too small to read click on the printer icon when the menu pop up appears at the bottom of the page.
Cdminter55 is offline
post #6 of 7 (permalink) Old Jul 31st, 14, 08:40 PM
Vega$69's Avatar
Ok so you'll be over 600 hp. Pull power from the main terminal on the core support or the horn relay buss fused with and in line 30 amp fuse to a relay triggered by 12v ign from the key switch
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #7 of 7 (permalink) Old Jul 31st, 14, 08:50 PM Thread Starter
Cory
Thanks for the help Guys I appreciate the responses.
