Tach bounces at startup - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 3rd, 14, 09:32 AM Thread Starter
Howard
I searched and found lots of issues with using HEI ignition and either OEM or aftermarket tach but I couldn't find the issue I am having.
I replaced my factory tach in my 69 camaro with the reporduction OER tach. The factory tach worked fine until I accidentally broke the needle off. The car has a completley stock ignition. I grounded the tach wire along with the headlight switch. I double checked the ground and it is good.
The issue I'm having is that the needle goes crazy when starting the car. Once it is started, it works fine but there is a small amount of movement when I use the directionals. The start up movement is so bad, it looks like it could snap off the needle. It actually goes from negative RPM to 5K really quicklly and bounces around erratically until the car starts.
I got the part and directions to make the tach filter but everyone says it is for HEI ignition. I'll probably go ahead and try it anyways but since I shouldn't need it, I thought I would post here first to see if anyone had other ideas.
hlasagna is offline
post #2 of 6 (permalink) Old Aug 4th, 14, 03:19 AM
Re: Tach bounces at startup
Install a spike arresting diode in the tach power supply line.
1N4005, 1N4007 would work.
Install with line side to power source.
If no 1N400X, then get a 1/2 amp 16-18 volt Zener diode.
Install the same direction.
Your problem is a coil is energizing when key turns on.
If you are engaging the starter and the needle action occurs at the same time, then the solenoid coil is sending a spike through the electrical system.
post #3 of 6 (permalink) Old Aug 4th, 14, 03:08 PM
Steps
Also check, if a gm type hei, the bannet connection where it goes up into the dizzy cap.. it is actually on the pin and not jambed beside it... check with a small mirror
Steptoe is offline
post #4 of 6 (permalink) Old Aug 4th, 14, 09:26 PM
69z28freak's Avatar
My tach does the same thing and I just installed a Petronix ignition. I wonder if there is a connection? My tach is also new. I thought it was normal, but my car did not have a tach before.
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
post #5 of 6 (permalink) Old Aug 5th, 14, 07:20 AM
I installed an aftermarket Autometer tachometer in my '69 Camaro (stck, non-HEI ignition) and the readings were erratic and spiked frequently. I contacted Autometer and they suggested I install a 10K, 1/2 watt, resistor in the green tachometer wire. I did and that fixed the issue.
Not sure if that helps... it's an easy thing to try though.
69OlympicGoldSS is offline
post #6 of 6 (permalink) Old Aug 5th, 14, 01:34 PM Thread Starter
Howard
I contacted OER and they were no help whatsoever. The support person started talking about the tachometer feeding back through my audio system. Not sure how he even came up with that. It's a 1979 Pioneer 8 track. Not exactly what you could call an audio system .
I guess I'll start trying the diodes and resistors mentioned above but it seems like if the factory tach worked, the new electronic tach should work the same. I'm try to use original parts but this is one of the few cases where I went with a reproduction. It always seems to bite me though.
hlasagna is offline
Tags
tach, tachometer
