Coolant seneor test - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 4th, 14, 08:34 AM Thread Starter
Coolant seneor test
Can I see a re-post of the test used to check the coolant sensor? Also, if I just pull the sensor will I have a lot of coolant to clean up, or do I drain the coolant first?
moses david is offline
post #2 of 3 (permalink) Old Aug 4th, 14, 12:03 PM
Karl
VetteFreak's Avatar
Re: Coolant seneor test
I usually drain about a 1/2 gal of coolant or so from the radiator...remove the sensor, otherwise you'll get fluid from the intake. If the sensor is in the head at the exhaust manifold, you'll need to remove enough to get below the opening...maybe 1 & 1/2 gal. Take an ohmmeter and check across the connection tab and the base. If you have the stock sensor, it should read about 400 ohms at 100 deg F. Heat a small pan of water on the stove to boil and place the bottom portion of the sensor in the water and allow it to heat thoroughly. At 212 deg F or boiling, it should read about 100 ohms. If the readings from the sensor are close to the numbers mentioned and the console gauge is stock and functioning, it should read as designed.
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #3 of 3 (permalink) Old Aug 4th, 14, 12:30 PM Thread Starter
Thanks VF, I'm printing out these for a reference for myself. Team Camaro has been my resource and inspiration.
