1967 Dash Harness - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 13th, 14, 05:47 PM Thread Starter
Sam
1967 Dash Harness
Where does this plug into the body? It looks like it would be somewhere close to the cluster, but I don't see a hole. Thanks for the help!
vtbogey is offline
post #2 of 6 (permalink) Old Aug 14th, 14, 05:42 AM
Roger
rogerh's Avatar
Re: 1967 Dash Harness
We will need a better picture of maybe a connector.
Roger
rogerh is offline
post #3 of 6 (permalink) Old Aug 14th, 14, 06:45 AM
Doug
I agree you need to take a picture of the area you are working in. Also take a picture of the harness that is being installed. It looks like you are working on the under the dash harness but not sure. If it is a front light harness or a engine harness say so not into guessing games.
Cdminter55 is offline
post #4 of 6 (permalink) Old Aug 14th, 14, 06:09 PM Thread Starter
Sam
Sorry for the lack of information. I'm working on the under dash harness (includes the fuse box). My question is about a spear looking plug that is taped to the harness. It serves no electrical purpose. It looks like it would plug in somewhere to support the wiring itself. I'll post some better photos. Thanks guys for the help. I started on this car in 2002 and it is hard to believe it is coming together.
ID:	83714   Click image for larger version
ID:	83730   Click image for larger version
vtbogey is offline
post #5 of 6 (permalink) Old Aug 15th, 14, 03:11 AM
69-Pace's Avatar
Yes it is a common way of securing the harness to the frame of the dash. It inserts to a drilled hole in the supports.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 6 (permalink) Old Aug 15th, 14, 06:00 AM
Michael
That might be the retainer that plugs into the firewall above the steering column. Look for the hole.
mahunt is offline
