tach connectors - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 14th, 14, 05:15 PM Thread Starter
dzs
Apprentice
darryl
tach connectors
I need the L connectors on the back of a 69 tach the 2 metal connectors that the wiring plug plugs into Does anyone know where i might be able to find them?
dzs is offline
post #2 of 5 (permalink) Old Aug 14th, 14, 05:39 PM
Karl
VetteFreak's Avatar
Re: tach connectors
National Parts Depot has the factory tachometer repro harness for $22.95. Part #C-2483-3B or make your own with single push plugs to each connector. 12 volt supply...Coil connection...Ground.
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #3 of 5 (permalink) Old Aug 14th, 14, 05:41 PM
69-Pace's Avatar
Re: tach connectors
You could call M & H Electric Fabricators http://www.wiringharness.com/
Lectric Limited http://www.lectriclimited.com/mainpage.htm
and Mad Electric http://www.madelectrical.com/catalog.shtml
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 5 (permalink) Old Aug 15th, 14, 01:34 PM Thread Starter
dzs
Apprentice
darryl
Re: tach connectors
I must not have been clear I have the wires and plugs I need the L connectors that are on the back of the tach thanks
dzs is offline
post #5 of 5 (permalink) Old Aug 15th, 14, 02:37 PM
69-Pace's Avatar
Re: tach connectors
Then call Don's Speedometer and see if they can help you out, Or Mike in North Kingstown http://www.amcri1.com/#&panel1-1
69-Pace is offline
