Hot Tach Wire - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 15th, 14, 04:50 AM Thread Starter
Bruce
Hot Tach Wire
While tuning my carb, I noticed a spark from the dangling tach wire on the throttle rod, so when I moved it away it was hot as ****. I taped it up out of the way for now. The car has an HEI. What is going on and should that wire be so hot?
The Camaro Guy is offline
post #2 of 3 (permalink) Old Aug 15th, 14, 07:16 AM
Jason
blue89bird's Avatar
Re: Hot Tach Wire
Is the insulation on the wire stripped from rubbing against something? Could be the wire itself is chaffed and it's causing extra resistance and therefore heat
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #3 of 3 (permalink) Old Aug 15th, 14, 08:35 AM
69-Pace's Avatar
Re: Hot Tach Wire
If this is the signal feed wire it should be null unless one end is on the coil on a standard ignition. Since you are HEI and it is not connected I assume you Tachometer is being fed some other way?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
