wire tach direct or filter it? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 19th, 14, 04:16 PM Thread Starter
I have a 69 Camaro I am going to finally wire my tach
Some have said you need a filter of some sort between dist and tach others said no. Got the special harness from Ricks Camaro as well as the dash mount tach. It is where the gas gauge once was which moved to the old clock position(Till I find a console gauge set up I can afford)
So do I wire the tach direct or with some filter? I have a new Accel dist after taking my old MSD system off.
Orange 69 Camaro is offline
post #2 of 4 (permalink) Old Aug 19th, 14, 06:04 PM
69-Pace's Avatar
Re: wire tach direct or filter it?
If you are running factory points ignition, no filter. If you have upgraded to any kind of HEI system then more then likely you will need a filter for a factory style or OEM tachometer.
You can try without and see how your particular system behaves.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 4 (permalink) Old Aug 20th, 14, 06:28 PM Thread Starter
Would like to see whats involved with the radio shack filter. Yes I need one,,where do I find that info???
post #4 of 4 (permalink) Old Aug 20th, 14, 06:38 PM
69z28freak's Avatar
This is the first I have heard that I would need a filter on my Tach. I am running a Pertronix Ignitor II. IS that why my tach is bouncing all over the place when I start it? I already had to run a direct wire from my fusebox to the coil, which I had to change as well from stock. 69 Z/28.
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
