Lights on!! - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 21st, 14, 06:02 PM Thread Starter
Darren
Lights on!!
I rewired my 69 with the update aaw harness and all the lights work as needed, but for some reason when I pull the head light switch on to either running light position or headlight position, the signal light , in dash ,turn indicators are both on. When I turn the signal lights on (when I put the key on ) the indicators work properly, but as soon as I turn the signal switch off, both in dash indicators stay on. Is this normal? I don't think so.
Doesn't make a difference wether the key is on or off.
Any idea?
chevysrule454 is offline
post #2 of 6 (permalink) Old Aug 21st, 14, 06:09 PM
Vega$69's Avatar
Re: Lights on!!
Check the ground on the parking lights
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 6 (permalink) Old Aug 21st, 14, 07:04 PM
Re: Lights on!!
Hazard button on the side of the steering column pushed in?
brian2013 is offline
post #4 of 6 (permalink) Old Aug 22nd, 14, 04:51 AM
Chris
Re: Lights on!!
check ground on instrument cluster
shoddy_F-body is offline
post #5 of 6 (permalink) Old Aug 28th, 14, 10:02 AM Thread Starter
Darren
Re: Lights on!!
So the grounds seem to be the common denometer here...ok I will check them. Don't know if this makes a difference, but every second time or so, that I pull the light switch out, only one (the right) of the signal indicators comes on, the left side is out. Still though strangly enough, everything works properly...even the fourway flashers and there switch....grounds can do strange things huh?
post #6 of 6 (permalink) Old Aug 28th, 14, 11:04 AM
Doug
Re: Lights on!!
Check out these two diagrams to find all the grounds and make sure all of yours are connected. http://www.americanautowire.com/PDFL...20IN%203.0.pdf The back of the instrument panel should also be grounded.
Cdminter55 is offline
