Almost done wiring. No blinkers - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 28th, 14, 09:15 AM Thread Starter
I just put aaw dash,engine, and front light harness in my 68. Everything works as it should except blinkers. Any Ideals? The hazards work if that has anything to do with it. I got new flasher in fuse box and made sure it works, and checked/clean all grounds around the blinkers. They worked before rewire. Probly simple fix, im just new to wiring and glad everything else works so far.
68 camaro, 350 vortec heads, rpm air gap, lunati voodoo cam, coated headers, th350, 100 shot, 3.73, eaton posi.
justincat is offline
post #2 of 8 (permalink) Old Aug 28th, 14, 09:55 AM
69-Pace's Avatar
Re: Almost done wiring. No blinkers
If you have the factory fit line then you need the signal flasher under the dash by the radio. If you did a AAW classic update to blade fuses both flashers are on the fusebox.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 8 (permalink) Old Aug 28th, 14, 12:43 PM Thread Starter
Ok, I see. I went from a painless kit that had its own flasher and my car dont have it. Can i use a normal flasher like in fuse box? Do I have to run a hot wire to the flashers to get power to the turn signal wires? Because i dont even have constant power to the wires when i turn on my blinkers. I guess if I had power there i could make them blinkThanks
post #4 of 8 (permalink) Old Aug 28th, 14, 01:22 PM
69z28freak's Avatar
Make sure that your brake light switch is properly adjusted. I had the same problem until I adjusted the brake switch plunger. Also you need the flasher only for the pulsing, the lights should already have power, but only if the brake switch is set correctly. Obviously fuse is in the chain as well.
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
post #5 of 8 (permalink) Old Aug 28th, 14, 01:49 PM
69z28freak's Avatar
Also note that I was testing all of my wiring harnesses as I went before I had everything connected and that was part of the problem. Once I made sure that everything was hooked properly most of the issues I had were no longer issues.
My Build Thread
post #6 of 8 (permalink) Old Aug 28th, 14, 03:19 PM Thread Starter
ok, thanks for the help guys. I didn't notice but the aaw harness had a plug for a flasher in the harness. I put a flasher in and everything is fine. I didn't know that was were the power and the flasher was coming from. I also want to give a good word for the guys at American auto wire. They have a great product and excellent customer service. My car was missing all the plugs from the car side of the harness, a lot of the colors didn't match and they walked me threw any problems I had. I was pretty much scared of any kind of wiring issues. I learned a lot and it wasn't as bad as what I thought
post #7 of 8 (permalink) Old Aug 28th, 14, 05:27 PM
69-Pace's Avatar
No you are all good unless you use LED's that require a special flasher and additional grounds. Standard flasher or Heavy Duty are fine for both hazards and blinkers.
69-Pace is offline
post #8 of 8 (permalink) Old Aug 28th, 14, 08:20 PM Thread Starter
gotcha, Ill put leds on the wanted list. But for know im going to just cruise around for awhile and enjoy everything working. lol
