hooking up electric choke - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 28th, 14, 10:56 AM Thread Starter
Apprentice
Sam
Wheres the best spot to get power for electric choke with out butchering
wire harness. Need key power.
Sammy T
samstheman is offline
post #2 of 3 (permalink) Old Aug 28th, 14, 11:47 AM
Andrew
Andrew69's Avatar
Re: hooking up electric choke
The horn relay should have a wire that is hot when the key is turned. No butchering needed.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 3 (permalink) Old Aug 28th, 14, 12:19 PM
yep, I ran mine to the acc spot on the fuse box. Just put an inline fuse on it and a female connector and plug right in
68 camaro, 350 vortec heads, rpm air gap, lunati voodoo cam, coated headers, th350, 100 shot, 3.73, eaton posi.
justincat is offline
