Voltage Regulator - Bright/dim headlights? - Team Camaro Tech
post #1 of 35 (permalink) Old Aug 30th, 14, 01:33 AM Thread Starter
mshaw67's Avatar
On a road trip, no tools with me, Gen light comes on. Helpful guy pulls out DMM and we pinpoint alternator most likely culprit. New alternator and back on the road. Already replaced battery, cable, visible link before the road trip.
Driving at night, I notice the VR changing voltages. Usually headlights dimmer, then switch to brighter. Sometimes for a second, sometimes longer.
Is this expected behavior? Should I buy and install a new VR before my final leg in the journey? I've got another 600 miles to go.
Thanks,
mshaw67 is offline
post #2 of 35 (permalink) Old Aug 30th, 14, 02:38 AM
69-Pace's Avatar
Re: Voltage Regulator - Bright/dim headlights?
Old style mechanical Voltage Regulator I assume. You will benefit from upgrading to a Wells Airtex solid state Voltage Regulator. Mounts up the same way but does all the calculations for you, no manual adjustments required for seasonal changes and new batteries, alternators, belts etc that the mechanical style required - not that many do any adjusting of their mechanical ones hoping the last setting and calculation is still valid. The Wells units work great, and are designed to look like the OEM and even will take the high hat case cover of the old unit so no one ever know you upgraded to solid state technology.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 35 (permalink) Old Aug 30th, 14, 09:35 AM
click's Avatar
Wells VR715 is the part number you want, plug and play, easiest fix you can do on the car.
click is offline
post #4 of 35 (permalink) Old Aug 30th, 14, 10:23 AM
Probationer
Ted
also check all the connections on your vr. Mine had a bad end that took me a year to find.
twlove is offline
post #5 of 35 (permalink) Old Aug 30th, 14, 04:22 PM
I agree with the others, if you still have a mechanical voltage regulator upgrade to the Wells VR715 and you'll be happy you did as will your classic car.
NH69Z28RS is offline
post #6 of 35 (permalink) Old Aug 30th, 14, 05:05 PM
I had similar issues recently. Had to jump through hoops to get a Wells VR715 sent to me here in Canada and it worked amazingly. Changed from an Ammeter to Voltage gauge, and found a cracked plug on the alternator, that had a loose wire. All corrected and now everything works great. Did find when I was cruising at 60 in the evening the voltage gauge was at 12 volts only lights running. I booted it up to 70 and around 2500 rpms and it kicked it up to 14 volts and stayed there. Still all in all very happy with the fixes.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #7 of 35 (permalink) Old Aug 30th, 14, 06:21 PM
Craig
Craig1969's Avatar
Send a message via AIM to Craig1969 Send a message via MSN to Craig1969 Send a message via Yahoo to Craig1969
Fixed my EXACT symptoms with this exact part. Even run halogens now...no issues other than having to buy a GOOD dimmer switch.
Prepare to be the center of attention when you drive a first generation Camaro. You will be gawked at. Grown men & women will coo like children when you drive past. Children will scream like babies. Dogs & cats will get along. Does it get any better?
Craig1969 is offline
post #8 of 35 (permalink) Old Aug 30th, 14, 06:43 PM
Gordon
gordr's Avatar
I live in Canada as well and I ordered and received 5 of them from Rock Auto 4 years ago for $11.25 each. They ship directly to Canada USPS. Rock Auto now has them for $36.25...prices have tripled in 4 years! The Wells VR715 is a great VR as I blew 3 old style regulators with a 100 amp alternator in a short period of time. The Wells unit still works on the same setup today after 4 years...
67 Plain Jane being assembled with 427, 4 spd Muncie, 12 bolt rear with Mosers, 4 wheel discs
gordr is offline
post #9 of 35 (permalink) Old Aug 30th, 14, 08:14 PM
George
This is interesting. I switched to an internal regulator gm alt years ago. I always had problems with the vr on this car. Is there any benefit to going with a stock alt with the vr over the internally regulated unit? Other than it being correct and not a modification. I didnt cut any of the stock wires and could easily go back if there was a benefit.
carbuff67rs is offline
post #10 of 35 (permalink) Old Aug 30th, 14, 10:12 PM
69-Pace's Avatar
George - One of the more popular reads at Mad Electrical - one wire vs three wire alternators. http://www.madelectrical.com/electri...hreewire.shtml
69-Pace is offline
post #11 of 35 (permalink) Old Aug 30th, 14, 10:18 PM Thread Starter
mshaw67's Avatar
Thanks all for the info; I felt comfortable that I didn't need a VR. I made the final 600 mile just fine. 2,038 miles total.
The new electronic VR sounds like a winner.
mshaw67 is offline
post #12 of 35 (permalink) Old Aug 31st, 14, 02:42 AM
69-Pace's Avatar
Glad you made it back safe.
69-Pace is offline
post #13 of 35 (permalink) Old Aug 31st, 14, 07:42 AM
Just changed to electronic regulator myself. No more random dead batteries. Would always have a battery charger n jumper cables in trunk. Removed old regulator's cover and mounted it to the new electronic regulator by drilling a couple of holes. New regulator was a lot thinner. It now looks like a original regulator by installing the old cover.
David_396 is offline
post #14 of 35 (permalink) Old Aug 31st, 14, 09:18 AM
George
I just picked one up for 14.95 shipped. Should be here end of the week. Ive got 3 correct alts in the basement collecting dust. Maybe I'll play around a bit with that. The internal reg alt is nice but it is a tad bigger and almost hits my valve cover with the correct belt.
post #15 of 35 (permalink) Old Aug 31st, 14, 09:32 AM
69-Pace's Avatar
I'm always amazed at the price range for Wells/AirTex units.
I've picked them up on rockauto.com with our discount for 6 bucks and less, and others here have posted 40 bucks and more on-line through other retailers and at local auto parts stores.
69-Pace is offline
