replacing ignition switch - Team Camaro Tech
post #1 of 16 (permalink) Old Aug 31st, 14, 02:05 PM Thread Starter
peter
i read a few posts already after i unscrewed the chrome nut and ring and pulled switch out.
from what i read this is not supposed to pull out? leave in and do the paper clip?
putting the paperclip in and turning ccw isn't doing a thing but pissin my dog off
if i screw the ring back on, it doesnt appear to make a difference if its on or off while paper clipping and turning ccw.
i'm ready to take a cutoff wheel to this B-tch<~ just sayn
__________
'67, rs/ss
spooge is offline
post #2 of 16 (permalink) Old Aug 31st, 14, 02:47 PM
scblucam's Avatar
Re: replacing ignition switch
That's the way you do it. Make sure you push the paper clip all the way in.
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 16 (permalink) Old Aug 31st, 14, 04:14 PM
George
Put the key in the acc position. insert the paper clip in the hole. you should feel a resistance pushing back when you push all the way in. While its pushed in continue to turn the key ccw past the acc position. The lock cylinder should then pop out or be easily pulled out with the key. I just did this to one I have laying around to be sure.
carbuff67rs is offline
post #4 of 16 (permalink) Old Sep 1st, 14, 03:41 PM
Gordon
gordr's Avatar
I just pulled one off, did all the correct things in the procedures above, but the cylinder was gummed up and real sticky which I found out after grabbing the big ignition switch piece behind the dash and giving it a few yanks and twists and finally it popped out.
67 Plain Jane being assembled with 427, 4 spd Muncie, 12 bolt rear with Mosers, 4 wheel discs
gordr is offline
post #5 of 16 (permalink) Old Sep 26th, 14, 05:59 PM Thread Starter
peter
thanks guys, i finally got around to this tonight and with a lil this way that way it popped right out.
unfortunately, this didn't solve my problem..
problem: engine keeps running. thought it could be the switch.( but i got a new switch!)
i have some serious ground issues ever since the car came back from paint.
this will be a new post(s)
__________
'67, rs/ss
spooge is offline
post #6 of 16 (permalink) Old Sep 26th, 14, 06:07 PM
Vega$69's Avatar
Do you have an MSD box?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 16 (permalink) Old Sep 26th, 14, 07:07 PM Thread Starter
peter
yes i do
__________
'67, rs/ss
spooge is offline
post #8 of 16 (permalink) Old Sep 26th, 14, 07:12 PM
Vega$69's Avatar
yes i do
Did you install the diode on the alternator wire as instructed?
If not the engine will continue to run when the key is switched off.
See page #8
http://www.summitracing.com/search/p...word=oil%20pan
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #9 of 16 (permalink) Old Sep 26th, 14, 07:21 PM
B
See page #8
What do oil pans have to do with this?
Here is the link for the instructions
https://www.google.com/url?sa=t&sour...tOpNsP2e_05fxg
Formers: 1969 RS 350, 700HP 1967 Flash-in-a-pan Firebird 400, 2002 Z28 M6 1SC/1SZ
SnakeEyes is offline
post #10 of 16 (permalink) Old Sep 26th, 14, 07:22 PM Thread Starter
peter
i never seen a diode on my schematics.
crap, i just scanned down the pdf and there's a diode.
looks like i need a diode from MSD
thanks Vega
__________
'67, rs/ss
spooge is offline
post #11 of 16 (permalink) Old Sep 26th, 14, 08:31 PM
Vega$69's Avatar
Doh!!!!
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 16 (permalink) Old Sep 28th, 14, 07:28 PM Thread Starter
peter
Tanks and Oooops
__________
'67, rs/ss
spooge is offline
post #13 of 16 (permalink) Old Sep 30th, 14, 07:28 PM Thread Starter
peter
well that this post is off topic now or i just started off topic...
On page 8 of my MSD 6420 install .pdf., it says to install diode from terminal 4 (of regulator) to "charging light". huh?
wouldn't this be the positive line i have connected to my battery connect?
what the heck is the charging light? did i get ripped off and not have any cool lights on my msd? there's no mention but here that i see "charging light".
anyway, i ordered a few diodes thanks to a search here.
thanks for the help, and i'll report back
__________
'67, rs/ss
spooge is offline
post #14 of 16 (permalink) Old Sep 30th, 14, 07:42 PM
George
I think it refers to the idiot light in the dashboard which on my car is one of the wires connected to my alternator.
post #15 of 16 (permalink) Old Oct 10th, 14, 04:36 PM Thread Starter
peter
maybe too many beers, i was thinking i needed the diode installed to the MSD.
i'll give this a try... the terminal 4 connection shown in diagram.
not sure how this will do it. i better read up
thanks
__________
'67, rs/ss
spooge is offline
