Interior lights won't shut off? - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 1st, 14, 06:26 AM Thread Starter
Larry
Send a message via AIM to Pentagon Larry
Hello,
Can anyone help with a solution for my interior lights that won't shut off. I have a 68 convertible and the two lights that are at the bottom of the dash around the driver and passengers feet won't shut off. I recently had new interior and carpet replaced. I also had the little chrome rings on the dash knobs replaced and I hear there can sometimes be grounding problems. Thanks for your time.
Pentagon Larry is offline
post #2 of 8 (permalink) Old Sep 1st, 14, 06:42 AM
Camarodude67
Re: Interior lights won't shut off?
Probably a sticky door jamb switch. Push it is with your finger while door is open and do the same for the passenger side.
camarodude67 is offline
post #3 of 8 (permalink) Old Sep 1st, 14, 07:30 AM
George
Also check to see that the headlight knob is not turned all the way ccw into the notch as this will keep them on also.
carbuff67rs is offline
post #4 of 8 (permalink) Old Sep 1st, 14, 12:29 PM
Check that one the plastic bulb sockets hasn't become unclipped from the metal bracket. When this happens the side of the bulb base grounds itself on the bracket and your lights stay on.
BPOS is offline
post #5 of 8 (permalink) Old Sep 1st, 14, 02:42 PM Thread Starter
Larry
I checked both door jam switches and when both are pushed in, the lights stay on. I checked both light bulbs and they are fully in place? Now what can it be?
post #6 of 8 (permalink) Old Sep 1st, 14, 03:37 PM
69-Pace's Avatar
If you checked the headlight switch interior dimmer switch location and turned it counter clockwise past the click of full clockwise and you still have lights then the lead at one of the door jams is likely off the jam switch and grounding to the body. Those lights have power to the jam switch all the time and the switch grounds to light.
Remove both from the door jams and as soon as then come out they will lose ground if wired correctly, and if the lead is not attached or one and the lights are still on you found the ground.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 8 (permalink) Old Sep 1st, 14, 08:08 PM
Farm Boy's Avatar
It's possible that one of the screws in the door sill scuff plate was driven into the white wire in the interior light circuit. When the white wire is grounded the light comes on. The dome light wires run under the carpet on the drivers side. That's where I would look.
Farm Boy is offline
post #8 of 8 (permalink) Old Sep 3rd, 14, 12:16 PM
I agree with "69-Pace". Check for a wire off on one of the door jamb switches. Been there done that.
68RS/SS Convertible L48 (350/295 Powerglide)
daverichard is offline
