Factory 67 tach not reading rpm correct - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 3rd, 14, 08:22 PM Thread Starter
Dale
I finally got my motor running and the factory tach reads about 4 to 500 rpm higher than it should. I am running a msd6al box if that matters. Is there a way for me to fix this or do I need to have it calibrated. Thanks again guys for the help.
67 RS Camaro
71 SS Nova
68 Chevelle
67Dale is offline
post #2 of 2 (permalink) Old Sep 4th, 14, 03:49 AM
69-Pace's Avatar
Re: Factory 67 tach not reading rpm correct
Yes look on the MSD website for the Tachometer filters offered for points generation Tachometers.
You will need the correct one for your combination to make the factory tachometer happy - maybe. Some older Tachometers just can't hack the signal even with a filter, or are too sloppy to really be useful.
If it isn't happy even with a filter then you have the option to have the original rebuilt with new internals or run a non factory aftermarket set designed for HEI systems.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
