High/Low Beam Issue - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 6th, 14, 05:06 PM Thread Starter
Drew
High/Low Beam Issue
First time poster here. I have a '68. With the dimmer switch on, I have low and high beams. With the switch off, I have only high beams. Marker lights don't come on at all.
It's a new dimmer switch and new bulbs all around. All ground wires are accounted for, and I made sure there's a good ground w/the dimmer switch.
Beyond that, I'm not sure what the problem is.
Any suggestions?
Thanks all.
drews287 is offline
post #2 of 3 (permalink) Old Sep 6th, 14, 05:39 PM
Karl
VetteFreak's Avatar
Re: High/Low Beam Issue
Any suggestions?
Thanks all.
Make sure the #16 light green wire at the dimmer switch (lower connector) which runs to the headlights "high beam" is connected with a #20 LG wire which runs to the "high beam" indicator bulb. The power is fed to the dimmer (center connector) via #14 light blue wire from the headlight switch. The #16 tan wire on the dimmer (top connector) feeds the "low beams". The only thing unique to the side markers and the headlights is the "light switch". The #20 brown wire connected from the head light switch to the markers is completely independent of the headlight wiring, except, they share a #20 black common ground wire at the front. Are you certain the wiring is correct?
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #3 of 3 (permalink) Old Sep 6th, 14, 06:13 PM
69-Pace's Avatar
Welcome Drew. Don't forget to hit the Welcome Wagon and say hello, post some details on your 68, maybe even wow us with photos.
Was it all working before you replaced the bulbs and the dimmer switch?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
