electric fan wiring - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 7th, 14, 12:08 PM Thread Starter
Joe
electric fan wiring
Currently running my dual electric fans (via relays) to a constant 12 volt source (battery). Want to rewire them to a switched 12 v source. What's the best = under dash fuse block, horn relay, etc.?
joesauer is offline
post #2 of 6 (permalink) Old Sep 7th, 14, 01:04 PM
Steiner
Re: electric fan wiring
Can you better describe how they are wired?
The relays should perform the function of being the "switcher"....
Main power to relays should come from battery.
Coil supply/trigger to relays should come from temperature switch which is wired to a switched source, then the fans can only run if the key is on.
Typically it would be the relay coil positive wired to switched power, then the relay negative connected to the coolant temp switch (and toggle switch wired to ground if desired).
Yours don't run with the car off do they?
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 6 (permalink) Old Sep 7th, 14, 05:02 PM
I had mine on the horn relay so they'd come on with the motor running. I also carried a jumper wire after having a relay go bad.
Now with the LS motor I only need one fan running....and the other is switched so I can cool down faster between passes if needed
68 Camaro~LSx ~all motor
post #4 of 6 (permalink) Old Sep 7th, 14, 09:59 PM
Doug
Look at this wiring diagram for my Be Cool system to see if it will help you any. http://static.summitracing.com/globa...ss_install.pdf
Cdminter55 is offline
post #5 of 6 (permalink) Old Sep 8th, 14, 07:47 PM Thread Starter
Joe
Steiner. Mine are wired the way you describe except for the switched source scenario. I have a temperature sensor installed in the radiator that turns the fans on at 195 & off at 180. What I want to change is my SPAL relay wiring so the fans don't run with the engine off (until temp drops to 180 at which time fans do shut off). I'm not presently using a switched 12v source (so fans will never run with the engine off). Instead I'm currently wired (orange SPAL relay wire) to a constant 12v source. That's what I want to redo.
joesauer is offline
post #6 of 6 (permalink) Old Sep 9th, 14, 03:56 AM
Steiner
Joe, there's not many sources for switched 12V under the hood unfortunately. Just coil (which you don't want to use) and wiper motor (yellow wire) I think. The wiper feed can probably run it. Additionally there is an ACC and RUN spade on the fuse block inside the car. Either one of those can run it, just need a female spade and some wire. You can also put a small 3-5A fuseholder on it at the fuse bock although the circuit is fused.
'69 Camaro
500hp/538lbft
Steiner is offline
