How accurate our your gas guages? - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 13th, 14, 01:58 PM Thread Starter
Ken
I have a 68 with in dash gas gauge. I had issues with it that with the help of the forum I think I worked out. I pulled the dash and verified the gauge responded as expected when shorted. I tightened and added another ground to the dash pack just because while I was in there. I then found the ground at the harness and the tank and ground them clean and reattached. Seems to be working fine but maybe by my mileage calculation about 1/8 to /1/4 tank off. Is this about as accurate as it should be?
AlotHP68 is offline
post #2 of 5 (permalink) Old Sep 13th, 14, 02:57 PM
Guilton
Re: How accurate our your gas guages?
My stock 67 fuel gauge would go way past full BUT If it was on E you better be "At the gas station" and not "On the way there"!
planejane67 is offline
post #3 of 5 (permalink) Old Sep 13th, 14, 04:12 PM
Karl
VetteFreak's Avatar
If you're really concerned about accuracy, cut the brown wire under the dash going to the fuel gauge and splice a 0-25 ohm variable resistor (from Radio Shack) in series at a place where you can easily access it. Then, starting from "0", adjust the reading slightly each time you fill up the tank. I was able to get it almost perfect after 3 fill ups. Now, when the gauge is exactly at 1/2 tank, it takes 9 gallons to fill it...at full, the gauge reads slightly beyond FULL by about 1/16". I haven't had the guts to try going to EMPTY as yet.
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #4 of 5 (permalink) Old Sep 13th, 14, 04:32 PM
69-Pace's Avatar
Testing the output of the sender will also help you calculate and calibrate the gauge, but non spec readings indicate either an incorrect sender unit was installed in the tank or the unit is starting to fail.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 5 (permalink) Old Sep 13th, 14, 05:41 PM
Karl
VetteFreak's Avatar
Brian,
You're right about the matching of the sending unit to the gauge. In my case, the sending unit measured 0-94 ohms (close to factory spec)...Empty to Full. The console gauge is brand new and always indicated a lower than actual fuel level by at least an 1/8 - 3/16 of a tank. To compensate, I added the variable resistor to make the gauge read more accurately. This will not harm anything in the system and is working for me, so, it may help someone else who is seeking more accuracy of the gauge needle to add a simple correction mechanism.
Karl / VetteFreak
