Wiring Help! Connected battery and car tried to start. - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 17th, 14, 04:00 PM Thread Starter
Send a message via AIM to Briancp396 Send a message via MSN to Briancp396
I converted my 68 Camaro to HEI and utilized the 1 wire conversion pigtail for a newer alternator. Today, I hooked up my battery for the first time and the horn started blowing and the engine tried to crank (no one was in the car to turn the key!). Sparks were flying! Has someone had this happen before? I am completely lost. I am hoping it is something minor. Any troubleshooting tips will be appreciated. Thanks
68 RS Camaro, 350 cid, 4-speed
Briancp396 is online now
post #2 of 6 (permalink) Old Sep 17th, 14, 05:37 PM
Karl
VetteFreak's Avatar
Re: Wiring Help! Connected battery and car tried to start.
Sure sounds like you've got wires crossed somewhere. My '69 350 is converted to a stock GM HEI dizzy and single wire alternator with no problems. Did you eliminate the external VR and rewire the horn relay properly? Do you have the proper wire from the coil connected to the starter solenoid?
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #3 of 6 (permalink) Old Sep 17th, 14, 05:45 PM
How was it before it was converted to the HEI and the alternator ?. I'm not trying to be ignorant but sometimes people have bought things assuming things were fine only to find out they got taken. You know the story, a guy selling a car says it runs fine but when you want to hear it he says it just needs a battery and it will fire right up for you and you buy it and it needs more than just that.
If it was fine before I would look at all of the spots you worked on and did things to. I might think that maybe a wire is crossed or something goofy on the starter solenoid for it to crank over by itself or maybe on the HEI conversion it got wired to the wrong spot.
The horn though has me baffled as this is on a relay BUT I've seen stranger things before.
I would just look at what you have done real close. If all else fails disconnect what you did and connect the battery then disconnect it and connect one things and try the battery connection again. If it's fine move on to the next connection and so on one at a time.
SOA-Nova is offline
post #4 of 6 (permalink) Old Sep 18th, 14, 07:31 AM
Jeff
yellow69RS's Avatar
At the starter solenoid should be a purple wire and a yellow wire. The yellow wire goes to the coil on a points system. It has no use with HEI and should be disconnected and taped. The purple wire should be on the "S" terminal of the starter and nothing else there. The purple wire should only have power when the key is in the crank position.
Jeff
yellow69RS is offline
post #5 of 6 (permalink) Old Sep 18th, 14, 08:26 AM
Good suggestions given. Mine are:
1. A power cable is resting across solenoid BAT stud and S terminal and back feeding the ign power circuit via the R terminal on solenoid.
2. Pull off black wire on bottom of horn relay and measure continuity to ground on jusy pulled off black wire - should be an open - if not, insulation worn or horn button(s) have lost their spring pressure.
Everett#2390 is online now
post #6 of 6 (permalink) Old Sep 18th, 14, 09:38 AM
Doug
Look at the engine harness coming from the fuse box. It has a resistor wire which is usually white, black, and purple that goes to the + side of the coil. This wire need to be replaced with a new +12 volt wire from the fuse panel. Here is a wiring diagram of an alternator conversion http://www.lectriclimited.com/images...-vak6368cs.jpg
Cdminter55 is offline
