Do I need to relay my fuel pump? - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 18th, 14, 06:55 AM Thread Starter
david
Send a message via AIM to kabinet Send a message via MSN to kabinet
Putting in an LS3. The harness instructions say "The fuel pump is controlled by the ECM. The control wire supplies 12 V and is fused/relayed and should connect to the 12 V side of the fuel pump using 10 gauge wire (minimum size)." So it's already relayed and I just run a wire from it to the pump right?
Engine: 19301358
Computer: 19258267
Fuel Pump: GPA-4
kabinet is offline
post #2 of 3 (permalink) Old Sep 18th, 14, 07:01 AM
Vega$69's Avatar
Re: Do I need to relay my fuel pump?
Engine: 19301358
Computer: 19258267
Fuel Pump: GPA-4
What harness are you using?
The GM Performance Harness has the Fuel Pump Relay included in the Fuse Box. If so then run the designated wire to the pump.
If you are using a stock modified harness or custom harness it may or may not have the fuel pump relay built into it.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 3 (permalink) Old Sep 18th, 14, 07:55 AM Thread Starter
david
This is great news. I am using the GM harness. Thank you!
kabinet is offline
