Modifying A 69 Wiring Harness - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 19th, 14, 07:22 PM Thread Starter
Pat
67restoproj's Avatar
Just wondering if anyone has modified their existing wiring harness. I want to change from a standard mount fuel gauge to a center mount to add a tachometer.
1988 Players Challenge Camaro #88Tony Morris
1988 Players Challenge Trans Am 1 of 20
1969 Chevy C-10 LS 6 spd
67restoproj is offline
post #2 of 8 (permalink) Old Sep 19th, 14, 07:44 PM
Lynn
Re: Modifying A 69 Wiring Harness
The tach takes an "add on" wire harness. Several vendors sell it.
Center fuel gauge uses the same connector as the big fuel gauge.
You do not need to modify the harness.
Lynn
bilodeaulynn is offline
post #3 of 8 (permalink) Old Sep 19th, 14, 08:10 PM
69-Pace's Avatar
Pat - It is a simple swap, cutting the dash carrier is the hardest part but a Dremel tool makes easy work of it. Do you need the the template? I attached the simple one, I can email you a larger template in PDF form if you like.
I like your floor supervisor, he looks approving of your work.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 8 (permalink) Old Sep 19th, 14, 08:13 PM Thread Starter
Pat
Thanks for the info Lynn! I thought I might have to lengthen the fuel gauge wires but I might be able to open up the harness and pull them back
post #5 of 8 (permalink) Old Sep 19th, 14, 08:22 PM Thread Starter
Pat
Thanks Brian. I am going to order the new gauge and will need a template.
Yes she is a great supervisor and not much gets past her.
post #6 of 8 (permalink) Old Sep 19th, 14, 08:24 PM
69-Pace's Avatar
Best car alarm made. I'll drop the pdf version of the template to your email.
69-Pace is offline
post #7 of 8 (permalink) Old Sep 19th, 14, 08:28 PM Thread Starter
Pat
Yup you bet!!!! Thanks very much Brian!
post #8 of 8 (permalink) Old Sep 19th, 14, 08:34 PM
69-Pace's Avatar
In route to your hotmail account.
69-Pace is offline
