LS3 GM Harness to T56 VSS doesnt fit - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 2nd, 14, 03:28 PM Thread Starter
david
Send a message via AIM to kabinet Send a message via MSN to kabinet
LS3 Engine: 19301358
Engine Wiring Harness: 19258267
T-56 Magnum Transmission: TUET-11009
I think my T-56 came with a Ford Vehicle Speed Sensor. American Powertrain says they all do, even though I ordered for a GM LS. My Wiring Harness looks like this. The plug that fits into my vss looks like this.
Should I splice them together? Or is there an adapter harness? Or should I order a new VSS?
kabinet is offline
post #2 of 9 (permalink) Old Oct 2nd, 14, 03:35 PM
Chris
130fe's Avatar
Re: LS3 GM Harness to T56 VSS doesnt fit
I am using a similar GMPP harness, you are talking about replacing the plug form the PCM harness correct? If so, Just splice in the plug that fits. One is a reference and the other is ground. I would just match the colors up and be sure to use some heat shrink or something similar.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #3 of 9 (permalink) Old Oct 2nd, 14, 03:36 PM
Bruce
I spliced in the Ford connector that I got from Summit and have had no problems. It's a shame that there has to be Ford parts on my Camaro but at least they work.......
BShyster65 is offline
post #4 of 9 (permalink) Old Oct 2nd, 14, 03:43 PM Thread Starter
david
Swell, Thank you! I will do that then
kabinet is offline
post #5 of 9 (permalink) Old Oct 2nd, 14, 03:47 PM
Chris
130fe's Avatar
Does your harness have a wire for the reverse lockout? Mine didn't, I added a pin to my PCM to make it work. Not too hard, just a little wiring. Let me know if you want the info.
Chris
130fe is offline
post #6 of 9 (permalink) Old Oct 2nd, 14, 04:08 PM Thread Starter
david
Mine didn't! The info for it would be great, thank you!
kabinet is offline
post #7 of 9 (permalink) Old Oct 2nd, 14, 04:10 PM
Chris
130fe's Avatar
Send me your email.
Chris
130fe is offline
post #8 of 9 (permalink) Old Oct 2nd, 14, 04:57 PM
Garth
Me too....
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline
post #9 of 9 (permalink) Old Oct 2nd, 14, 09:09 PM
Chris
130fe's Avatar
Give me a couple of days and I will compile a good write up and post it.
Chris
130fe is offline
