Rear wires - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 5th, 14, 03:04 PM Thread Starter
Michael
Rear wires
Just installed a new gas tank,Trunk pans,Tail panel etc.Installed new rear wire harness and noticed the fuel tank wire and the license light wire are to run threw the same hole in the rear of the Camaro??There are 2 grouments and 1 hole?Do they both go in the same hole??Thanks
mpeters is offline
post #2 of 2 (permalink) Old Oct 5th, 14, 04:37 PM
Steven
stamatisg1977's Avatar
Re: Rear wires
the license plate wire goes thru the grommet that exits the tail pan
the fuel sender wire goes thru a hole that is behind the trunk latch. repro trunk pans do not have this hole. you have to drill. a precise position of the hole is center of the fill neck hump about 3/4 of the way toward the latch brace from the back of the tail pan
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
