67 Windshield washer pump - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 7th, 14, 10:54 AM Thread Starter
Rob
I am using a stock wiper motor in my 67 convertible. I bought a replacement washer pump. It came with no instructions. I installed it by using the one bolt on the top passenger side of the pump, under the plastic cover, with the spacer, and the lower driver's side bolt. It worked, but would not disengage. Basically the arm would rotate the gear until it reached a certain point, and then start pulling air. I thought the pump was bad, so I ordered another one, this time an AC Delco brand. When it showed up, it was the EXACT same pump as the no-name brand, but came with instructions. The instructions said for 67 and earlier models, use the long bolt and spacer in the upper passenger side location, under the cover. For 68-69 models, use the upper passenger side outer bolt and lower driver's side bolts. This implies that you only use one bolt on the 67. I tried it. It worked, and it disengaged. For giggles, I installed the lower driver's side bolt, and it acted like the first pump, and didn't disengage. The thing is, with just the one bolt installed, it moves around allot, and is very loud. It doesn't seem right. I know these replacement pumps are not correct for 67s, but they are all that is available as far as I know. Is this what they intend for a 67? If anyone has any experiences to share, or suggestions to offer, I'd appreciate it.
rsimons is offline
post #2 of 8 (permalink) Old Oct 7th, 14, 11:23 AM
Michael
Re: 67 Windshield washer pump
The replacement pumps are supposed to use 2 bolts to attach to the wiper motor.
The first bolt on the driver's side you got right.
The bolt on the passenger side is the tricky one.
Obviously, there is a nice hole on the flat next to the stamped riser, but that's for the 68-69 cars and it doesn't line up for the 67 wiper. The 67 cars use the hole that's on the riser (and in the right spot) with the spacer between the riser and the wiper motor.
Use this example for clarity.
http://www.chevytalk.org/fusionbb/sh.../post/2222633/
mahunt is offline
post #3 of 8 (permalink) Old Oct 7th, 14, 11:30 AM Thread Starter
Rob
Thanks mahunt,
When I bolt it up like that, with the passenger side on the riser with the spacer, and the lower driver's bolt installed, it doesn't disengage. When I remove the lower driver's side bolt it does disengage, but moves around while operating.
rsimons is offline
post #4 of 8 (permalink) Old Oct 8th, 14, 05:43 AM
Michael
Put a washer between the pump and the wiper body and then tighten down the driver's side bolt?
The kits usually come with a new, lower design pump rotor (the 4 cogged thing that operates the pump).
Did you get one?
mahunt is offline
post #5 of 8 (permalink) Old Oct 8th, 14, 06:49 AM Thread Starter
Rob
Thanks for the quick reply. I did replace the rotor. I'll try the washer.
rsimons is offline
post #6 of 8 (permalink) Old Oct 19th, 14, 07:57 AM Thread Starter
Rob
Just a quick update. I tried the washer, but no luck. I noticed that i was having to put tension on the spring to get the driver side bolt in. I slotted the driver side hole inboard and down so the bolt would go in freely. Now it works great. Thanks for the help.
rsimons is offline
post #7 of 8 (permalink) Old Oct 19th, 14, 12:57 PM
Steps
This is why most pumps are replaced.....and a very simple fix...a very small tag from a mig welder, couple stokes of a fine file on the lever... place and good for another 20 yrs
I have described the how to in old threads on the subject.....
All the issue is is a slightly thou s of an inch worn on the metal bit in the rectangle hole the catches the cam.
Steptoe is offline
post #8 of 8 (permalink) Old Oct 19th, 14, 01:18 PM Thread Starter
Rob
This one was a brand new pump, so it wasn't worn. It simply was out of alignment. Slotting the hole allowed it to bolt up without it being in tension
rsimons is offline
