Radio Antenna - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 9th, 14, 05:30 AM Thread Starter
Jeff
Radio Antenna
Was the antenna that came with a 67 am radio the same antenna that came with the am/fm radio? If not, is the actual extending antenna that screws into the base on the fender the same? Thx
jockwalker is offline
post #2 of 3 (permalink) Old Oct 9th, 14, 08:51 AM
69-Pace's Avatar
Re: Radio Antenna
Telescoping antennas were general AM band antennas and you adjusted the height of the mast (or should have ) as needed to cut static or increase static as needed. Fixed mast antennas were for FM and if combined AM reception. There are different embellishments on the AM telescoping antennas used on first gens. Some refer to the ball as a tic-tac and the collar had variances.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 3 (permalink) Old Oct 9th, 14, 06:41 PM
Re: Radio Antenna
My 68 has a rear mounted electric antenna that is now broken.
How do i go about finding one that fits without over spending?
cruzin is offline
