Stupid Question: - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 13th, 14, 02:51 PM Thread Starter
Stupid Question:
My camaro (68) doesn't have a gas gauge for whatever reason. (car was a hack job and I am trying to turn the ship around) so I am going to order up a gauge cluster with the fuel gauge included (my gauges are worn down and I would like to spruce her up). Now my question is this:
All the gauges, speedo, tach, fuel, oil, etc would be MECHANICAL gauges correct and not Electrical?
I don't have a PCM or ECU or any computer in the car. So it would be mechanical?
Maybe I am wrong. Was always confused by this.
Thanks for entertaining this question for me.
Sixety8 is offline
post #2 of 5 (permalink) Old Oct 13th, 14, 03:27 PM
Re: Stupid Question:
speedometer...mechanical
tachometer....electrical
fuel......electrical
oil....could be either....I prefer mechanical
Voltmeter....electrical
I like gauges Vs. idiot lights
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old Oct 13th, 14, 03:32 PM Thread Starter
thank you
Sixety8 is offline
post #4 of 5 (permalink) Old Oct 13th, 14, 04:25 PM
Doug
You can also get an aftermarket panel and gauge set with mechanical or electrical gauges. I have electrical gauges which came with all the sensors and wiring harness. You can just about order with any gauge package you want. Check out their website : http://classicdash.com/product/1967-...-meter-gauges/ I bought the blank panel and bought these gauges from Speedway Motors. I had to purchase the tach. separtely. http://www.speedwaymotors.com/Auto-M...ontent=Default
Cdminter55 is offline
post #5 of 5 (permalink) Old Oct 13th, 14, 07:18 PM
Personally I favor mechanical gauges. That being said I hope no cash has changed hands yet as your fuel level gauge issue is 90% most likely a bad ground. Might be another 8% a defective sending unit in the tank and about 2% of the time it is a bad gauge.
A gas gauge (aside from a cork with a coat hanger stuck in it; poking through the gas cap of the gas tank in front of the cowl of a L-16 "Bird Dog" spotter plane that I learned to fly with a half century or more ago) are rarely mechanical. It is nothing more than a volt meter measuring voltage to GROUND by way of a float activating a rheostat. Without a good ground nothing works.
Big Dave
Larger Dave is offline
