What are the wire colors for the high and low beam? - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 18th, 14, 05:11 PM Thread Starter
Chris
Hi, I am installing relays for my headlights. Before I cut anything I want to make sure I am cutting the correct wire.
I am using the relay kit from MAD and I have a 1969 SS. Thanks!
Deevis69 is offline
post #2 of 4 (permalink) Old Oct 18th, 14, 05:47 PM
Re: What are the wire colors for the high and low beam?
Low beam is tan
High beam is light green
You can buy a relay harness that just plugs in to your existing h/l harness - no cutting required. EXAMPLE: http://www.ebay.com/itm/CERAMIC-H4-7...e25827&vxp=mtr
BPOS is offline
post #3 of 4 (permalink) Old Oct 18th, 14, 07:45 PM
69-Pace's Avatar
x2 on the ceramic socket relay harness, plug and play and 100% reversible.
If you have already bought and want to use the MAD relays you can, just replace the relays the harness comes with.
Or make your own harness and insert your MAD relays. Several members have posted their own home made ones. The materials are readily available on-line or at most big box auto parts stores. Some of the plans use two leads and two fuses - one for each light, others use one to power both. Either is a simple one night project IMHO for the DIYer.
But really when you add in the time and materials, the price is just about the same as making one yourself unless you don't value your time.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 4 (permalink) Old Oct 19th, 14, 12:10 PM Thread Starter
Chris
Thank you for the tip on the wiring harness - I didn't know those existed! I will look into that.
http://www.uapac.com/antique/box-h4-...t.html#q=34263
Deevis69 is offline
Tags
electrical wiring, headlights, relay
