What is it? - Team Camaro Tech
post #1 of 13 (permalink) Old Oct 26th, 14, 03:40 PM Thread Starter
What is it?
I will try to post a picture but there is a small "box" on the driver's side firewall Maybe 1" X 1/2" and it has two posts. its located to the right of the brake booster (looking at the firewall). I am asking because I just installed an AAW engine and light harness and had to disconnect one of the wires to get the old harness out but the new harness doesnt seem to have a wire for this.
Sorry for all the questions! This is one of many I am sure. Car wont start now and tech support wont be available until tomorrow.
1968, 383, 700R4, Convertible
Southtwnr is offline
post #2 of 13 (permalink) Old Oct 26th, 14, 03:43 PM Thread Starter
Re: What is it?
http://www.dre-si.com/68camaro/activ...20030803/1.jpg
its the box in the upper middle of this photo
post #3 of 13 (permalink) Old Oct 26th, 14, 03:50 PM
Re: What is it?
Looks to me to be an auto resetting circuit breaker. Where do the wire attached to it lead to?
NH69Z28RS is offline
post #4 of 13 (permalink) Old Oct 26th, 14, 03:50 PM
Camarodude67
Re: What is it?
Yes that is for your Power Top motor, 30Amp fuse.
camarodude67 is offline
post #5 of 13 (permalink) Old Oct 26th, 14, 03:54 PM Thread Starter
Re: What is it?
for my convertible top? Weird but the top wire was routed towards the front of the car.
post #6 of 13 (permalink) Old Oct 26th, 14, 04:00 PM Thread Starter
Re: What is it?
Yup. here it is
http://www.autometaldirect.com/chq-3...et-p-2141.html
thanks again. on to the next problem
post #7 of 13 (permalink) Old Oct 26th, 14, 04:13 PM
69-Pace's Avatar
Re: What is it?
Yes it takes direct power from the busbar then out the other side of the breaker to the power accessory - power top or power windows or both.
Sent from my iPhone using Autoguide
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 13 (permalink) Old Oct 26th, 14, 06:32 PM
omar
Re: What is it?
that wire comes from the horn relay its a single wire by itself like the a/c power feed
67 rs
70 rs
95 z28
omarcamaro is offline
post #9 of 13 (permalink) Old Oct 26th, 14, 07:51 PM Thread Starter
Re: What is it?
can anyone point me to a diagram of which post it should go to?
Here is a picture of the underside if someone knows.
https://www.camaros.net/techref/elect...horn_relay.htm
post #10 of 13 (permalink) Old Oct 26th, 14, 09:04 PM
Re: What is it?
Either of the two screw terminals
BPOS is offline
post #11 of 13 (permalink) Old Oct 27th, 14, 06:48 AM Thread Starter
Re: What is it?
Thanks BPOS
post #12 of 13 (permalink) Old Oct 27th, 14, 08:29 AM
George
Re: What is it?
That wiring / circuit breaker is called out in the AIM. For a '67 it's at UPC C06, sheet A1, on page 192. FWIW
67 RS Ragtop is offline
post #13 of 13 (permalink) Old Oct 27th, 14, 05:27 PM
Bobby
Re: What is it?
That's the spirit!!!
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180į Headers
black/black
no radio
Luwi67 is offline
