Fusible Link - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 27th, 14, 06:58 AM Thread Starter
Fusible Link
The one from the battery cable to the junction block behind the battery....is it really just a 14awg wire or is there something special about it? The local parts store only had the type with an actual fuse installed. Can I use a section of 14 awg wire and does the length matter?
1968, 383, 700R4, Convertible
Southtwnr is offline
post #2 of 7 (permalink) Old Oct 27th, 14, 07:03 AM
Re: Fusible Link
It is supposed to be "fusible link" wire. NAPA sells it 10' rolls. Not terribly expensive.
BPOS is offline
post #3 of 7 (permalink) Old Oct 27th, 14, 07:12 AM Thread Starter
Re: Fusible Link
I have another store to check that is closer than NAPA (wish those were common here) but will head there if need be. Thanks
post #4 of 7 (permalink) Old Oct 27th, 14, 07:17 AM
Ty
69&76's Avatar
Re: Fusible Link
San Diego...Auto Zone sells them
69&76 is offline
post #5 of 7 (permalink) Old Oct 27th, 14, 07:25 AM Thread Starter
Re: Fusible Link
Sorry. Need to update my profile. Im in South Florida now but AutoZone was the next store I was going to check. Seems to be harder to find stores that have a lot of these parts in stock for our old cars. Bennett Auto Supply didnt even have a tranny filter and gasket for 700r4 transmission!
Im whinning now. I'll stop
post #6 of 7 (permalink) Old Oct 27th, 14, 07:31 AM
Re: Fusible Link
The wire is not copper strand automotive wire. It is made of nickel-chrome steel wire (same stuff as glows red in your toaster) and is rated to carry Amperage in different amounts. Here is a picture of the wire without the poly-chloride vinyl plastic insulation:
If you are thinking of upgrading your wiring I recommend buying a circuit breaker rather than a fuse as a circuit breaker will rest and not leave you stranded on the side of the road.
These circuit breakers are also sold by amperage rating. The amperage rated is related to the rated capacity of your car's ORIGINAL alternator. If it was replaced with a 120 Amp one wire alternator to feed your power hungry stereo amplifier then your car could burn to the ground as the factory wiring isn't sized (gage of wire) to conduct that much power.
So a 36 Amp rated alternator would have a 40 Amp fusible link. A 67 Amp alternator would have a 70 Amp rated fusible link. You can buy circuit breakers sized in 5 Amp increments.
Big Dave
Larger Dave is online now
post #7 of 7 (permalink) Old Oct 27th, 14, 07:45 AM Thread Starter
Re: Fusible Link
DOH!! I just ran to Auto Zone and bought 9" of 14awg universal fusible link. My wiring is not really upgraded per se. I just replaced everything forward of the firewall with AAW factory fit harnesses. I do have a 105amp alternator in there....
Thanks for the suggestion though.
