Does wiper use a relay - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 28th, 14, 09:54 AM Thread Starter
Ken
So my wipers work if I push in on the knob. but when I turn the knob it doesn't work. My blinkers did the same thing and I replaced the relay and they work great now.
So I'm wondering if anyone knows where i can begin looking, if there is a relay, etc
thanks
Camaro68CA is offline
post #2 of 8 (permalink) Old Oct 28th, 14, 10:40 AM
Michael
Re: Does wiper use a relay
No relay on 1st gen cars (hopefully you're talking about a 1st gen car).
mahunt is offline
post #3 of 8 (permalink) Old Oct 28th, 14, 10:46 AM Thread Starter
Ken
Yes, a 1968.
Any idea why they wouldn't stay on without me just holding in the knob?
maybe knob is bad...
post #4 of 8 (permalink) Old Oct 29th, 14, 03:15 AM
When you push in the knob, you are requesting washers and wipers come on automatically.
I believe, the knob also turns to LOW speed as you push, then the operator manually turns off the wiper motor by turning the knob to OFF.
Motor power goes through the washer pump for wiping.
Might need a new wiper switch in the dash.
post #5 of 8 (permalink) Old Oct 29th, 14, 01:14 PM
Michael
Or cleaned.
Or grounded.
Or wiring checked.
mahunt is offline
post #6 of 8 (permalink) Old Oct 29th, 14, 07:01 PM
I have the same issue with my 67. , Since I don't intentionally drive it in the rain, it's not high on my list of things to fix. Now, if I knew exactly how to fix it, I would. I was betting on a bad ground. Now, I am not so sure. I hope you'll post what you find with yours and I'll do the same.
'67 RS/SS 396 4spd Muncie 12 bolt diff.
1941 Chevy 1/2 ton P.U.
moses david is offline
post #7 of 8 (permalink) Old Oct 30th, 14, 03:13 AM
Originally Posted by mahunt View Post
Or grounded.
Wiper switch body to dash is the ground path for wipers.
post #8 of 8 (permalink) Old Oct 30th, 14, 05:48 AM
Michael
Yes. And if it is missing the star washer or not tight enough (i.e., not grounding properly), the switch only grounds when the pressure if your hand forces switch body contact with the dash by pushing the switch in.
Release your hand, motor stops.
mahunt is offline
