Wire Harness Connector Terminal/ Spade - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 1st, 14, 08:18 PM Thread Starter
Timmy
Hi All
I need to find where I can buy these 3 Type of Wire Harness Connector Terminal/ Spade's.
One are the Type that are in the Front/ Back Lighting Plug harness and Lower console Disconnect - I do not know if 2 are used on each side or if there is a Male/ Female one for these.
The other are the Female side of the Firewall Disconnect - the Passenger Compartment side. I have the Male ones, could use more. I need the Female ones though.
Timmy
Name:	1960 Camaro Connector Plug Disconnect Terminals.jpg
ID:	91049   Click image for larger version
Name:	1969 Camaro Main Wire Harness Firewall disconnect Terminal Female.jpg
french69ssrs is offline
post #2 of 6 (permalink) Old Nov 1st, 14, 09:09 PM
ZZ_430's Avatar
Re: Wire Harness Connector Terminal/ Spade
American Auto Wire can fix you up.
Good searching
http://www.americanautowire.com/
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 6 (permalink) Old Nov 1st, 14, 09:18 PM
...or google delphi/packard
BPOS is offline
post #4 of 6 (permalink) Old Nov 2nd, 14, 04:49 AM
56 series http://terminalsupplyco.com/Store/De...133#Categories
Not sure about the other one, you'll have to look yourself.
COPO is offline
post #5 of 6 (permalink) Old Nov 2nd, 14, 07:23 AM
69-Pace's Avatar
Lectric Limited under the heading REPAIR COMPONENTS
(FOR WIRING HARNESSES) on the menu. http://www.lectriclimited.com/mainpage.htm
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #6 of 6 (permalink) Old Nov 21st, 14, 06:37 PM Thread Starter
Timmy
Originally Posted by french69ssrs View Post
Hi All
Timmy
As an Update, I have found that these Terminals are called Packard Double Lock.
I finally got one out to do a repair/ Splice and took some Pic's.
Thanks for the Links - went on each, and contacted these Suppliers, nothing.
Still looking for a few of these, they are not a Male/ Female type, you just use one for each wire and they slide past each other to make the Connection.
They are used for the Lower Console Wiring Harness, Rear Lighting Harness for my 69 Camaro. I'm sure they are used throughout other GM models.
Any help would be Great.
Timmy
Name:	1969 Camaro Connector plug terminals Double Lock.jpg
ID:	92569   Click image for larger version
Name:	1969 Camaro Connector plug terminals 004.jpg
