New Delco Battery not holding charge - Team Camaro Tech
post #1 of 20 (permalink) Old Nov 2nd, 14, 03:34 PM Thread Starter
I recently purchased a GM Delco battery for my 68. I have not driven it a lot and it sat for about a month. I went to start it and after 3 cranks it went dead. I charged it and it started right up. The next day same thing. I am getting 14 volts at the battery when running and l I was wondering if I have a bad battery.
I charged it to 13.2 then it slowly lowered to 12.4. volts with battery disconnected.
Not sure what to do.
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #2 of 20 (permalink) Old Nov 2nd, 14, 04:11 PM
Garth
Re: New Delco Battery not holding charge
I would say it's bad.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline
post #3 of 20 (permalink) Old Nov 2nd, 14, 04:32 PM
Check to see if there is a draw on the batt - with everything off and doors closed disconnect the neg cable and put a test light between the cable end and the neg batt terminal. If the test light illuminates something is drawing current. Pull fuses one at a time, closing door each time, to determine which circuit is at fault. If nothing found, disconnect wires to the alternator and do the test.
BPOS is offline
post #4 of 20 (permalink) Old Nov 2nd, 14, 08:05 PM
ZZ_430's Avatar
Would your battery happen to be a Delco "Professional"?
If so I've seen them go bad very quickly.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #5 of 20 (permalink) Old Nov 3rd, 14, 04:17 AM Thread Starter
Yes it is. What model should I replace it with?
Stewie is offline
post #6 of 20 (permalink) Old Nov 3rd, 14, 04:18 AM
69-Pace's Avatar
I've had no issues with AutoZone's Duralast line of batteries for side posts.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 20 (permalink) Old Nov 3rd, 14, 05:09 AM
Steiner
Just had a Duralast Gold lose a cell at a year old. Man, it's just hit or miss sometimes. They swapped it out and basically I lost about $30 because the price had dropped. Haven't had a problem yet with an Everstart Max from Wal-Mart though.
'69 Camaro
500hp/538lbft
Steiner is offline
post #8 of 20 (permalink) Old Nov 3rd, 14, 05:42 AM Thread Starter
Cost is not a factor, I just wanted something that worked. I like to have Delco in the car but I don"t see it happening. I am going to return it and see how the next one goes. I will be putting the car to bed for the winter so the battery comes inside. I had it charged last night and dissconnected. This morning it only took 5 cranks then it died again. 12.4 volts.
Stewie is offline
post #9 of 20 (permalink) Old Nov 3rd, 14, 07:59 AM
ZZ_430's Avatar
Well, I had a Sears Die-Hard Gold last for more than 7 years.
I've also had good luck with the Walmart batteries believe it or not.
The Duralast battery is ok, but I've seen them die prematurely.
You really can't beat the Optima though, and they are all I use now.
ZZ_430 is offline
post #10 of 20 (permalink) Old Nov 3rd, 14, 08:39 AM
If setting up for the winter, you might hook up a modern day charger in the 2 AMP position just to keep the new battery charged.
A battery has to be used and charged to keep its young looks.
Wally Mart Everlast was good when I was using them and Interstate is the brand I use now.
post #11 of 20 (permalink) Old Nov 3rd, 14, 08:55 AM
Paul B
Delco Proffesional batteries now have a straight over the counter exchange. If you purchased it recently, it should be here's my old one, here's your new one deal. That's what we do at the GM dealer I work at.
paulsstuff is offline
post #12 of 20 (permalink) Old Nov 8th, 14, 04:53 AM Thread Starter
Yes I took it in to Brian Cullen Motors and they did as you said. Originally the girl said they had to load test it, but then called later, and said they would replace it, I asked what it tested at and she said they didn't test it but would replace it. They asked for the VIN number and I told them it was a 1968 Camaro, but they used my VIN anyway to process the return. Now I hope the new one will be better. I wonder if my Vin is still on their computers, I do have the Zapora report for it.
Stewie is offline
post #13 of 20 (permalink) Old Nov 8th, 14, 05:17 AM
I'd return it and GM Pro Rates the batteries.
COPO is offline
post #14 of 20 (permalink) Old Nov 8th, 14, 05:47 AM Thread Starter
I did return it and it has a full replacement warranty. I only bought it in late July.
Stewie is offline
post #15 of 20 (permalink) Old Nov 9th, 14, 07:40 AM
Anne
I saw this battery charger on Jay Leno's Garage. Looks good :
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
