I need 67RS vert headlight door help - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 12th, 14, 02:55 AM Thread Starter
Head lights and doors worked but old sealed beams were not bright enough.
I installed a halogen relay harness from NPD. Lights and doors open.
Ign off, lites go out when ignition switch is off. Turn on ignition and doors close.
Problem: when lites are on, doors open and ignition switch on when shut off headlight switch the lites remain lit and the doors remain open. Turn off ign and lites go out. Turn on ign again and doors close.
Some how 12V DC is leaking to RS relays 2 & 3 and the new headlight relays.
Ignition switch, headlight switch, dimmer were replaced in 2010. I just replaced all 3 RS relays. Problem was not resolved.
Help please. Thank you.
slakis is offline
post #2 of 5 (permalink) Old Nov 12th, 14, 03:10 AM
69-Pace's Avatar
Re: I need 67RS vert headlight door help
We have seen this before. Pull a search for a recent thread.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 5 (permalink) Old Nov 12th, 14, 04:52 AM
Doug
Check out this website for troubleshooting the relays. http://www.retro-electro.net/FAQ67.html
Cdminter55 is offline
post #4 of 5 (permalink) Old Nov 12th, 14, 08:23 AM Thread Starter
Thanks for the reply. The first thing I check is the dimmer switch. I had 2 new in box. Both of them were defective. I am installing aNapa switch now, I'll let you know if it solves the problem.
Thank you again.
slakis is offline
post #5 of 5 (permalink) Old Nov 12th, 14, 09:02 AM Thread Starter
I have the RS schematics and the relay trouble shooting guide which I obtained from this sight. What is happening shouldn't be possible.
Thanks for the help. If I find the problem I will post it.
slakis is offline
