Which Wiring Harness? - Team Camaro Tech
post #1 of 16 (permalink) Old Nov 14th, 14, 09:06 PM Thread Starter
Dustin
I am having to do a complete rewire. Does anyone have a favorite brand of harness that they have had experience with?
Any help would be appreciated.
1967 RS Convertible, 454, M20 4-speed
dboz67rs is offline
post #2 of 16 (permalink) Old Nov 14th, 14, 10:14 PM
Larry
larryh56's Avatar
Re: Which Wiring Harness?
Almost all the recommendations on here are for American Auto Wire. They have stock, updated, etc. I ended up not using the engine bay section of my Painless harness and instead went went with the system from MadElctrical.com. I like his system better but it is not stock. The headlight relays work really well and made a huge difference in the brightness and what I can see at night. I wired my own gauges up as well.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #3 of 16 (permalink) Old Nov 15th, 14, 01:55 AM
AAW has 2 kits, one is "stock" replacement, the other is the "update" kit.
The update provides additional space/circuits for things like electric fuel pumps and other bells n whistles which weren't part of the stock offerings.
The update kit is UNterminated, so you'll have to crimp all the connections yourself once you determine proper wire length depending on how you want to route everything.
Each wire is marked on the insulation for what it's used for... good system.
Hanging on the Maine Coast...moved back North
1969 RS/SS, 383, 4spd, 373s, 12bolt, FatMat, Vintage Air - Super Red, and it's my first Camaro.
Engine pics
Radiator pics
Build album
Lobstah is offline
post #4 of 16 (permalink) Old Nov 15th, 14, 03:33 AM
Phil
Aaw
Full Car Media Blasting:
69TAPoser is offline
post #5 of 16 (permalink) Old Nov 15th, 14, 05:55 AM
American Autowire is the best. Stick with the original system as I did and you will not have any problems. Total plug and play with the correct terminations and colors to match.
Go to their website and educate yourself on what they offer and what is required for your vehicle. There are different looms based on the options in your car. Example: if you have a console car or no console. RS or non-RS, etc.
Don't waste your time with anything less.
Good Luck with your project
MJK-4 is offline
post #6 of 16 (permalink) Old Nov 15th, 14, 05:57 AM
68resto's Avatar
American Autowire has served me well many times. The company is great to work with. They did all the research and came up with a conversion harness for my wife's firebird Chevy engine conversion.
68 Cloned RS/SS w/ all the goodies.
67 Firebird w/ a Chevy 350
67 Camaro 6 cyl. 68,000 original miles
w/ wife & kids w/ the same addiction.
68resto is offline
post #7 of 16 (permalink) Old Nov 15th, 14, 06:19 AM
69-Pace's Avatar
In the interest of being fair here: As stated above by many - American Autowire is by far the leader for both OEM style harnesses sold under their "Factory Fit" product line using original style glass tube fuses and all factory colors and connectors, truly plug and play. And for the Auto-Resto-Mod folks the "Classic Update" series line using modern blade fuses and supporting options such as EFI/HEI and other customizations you want to add.
Painless is another popular line but they require you to finish off the leads and do not make a OEM style power distribution panel. I did one project with them and only because my buddy had already bought it and we were trying to get his ride running before deployment. He would have had a day or two longer in the drivers seat if he had purchased a Factory Fit harness, but the painless is still on the job I'm happy to say.
Mad Electrical and Lectric Limited also manufacture decent high quality harness and electrical components. I'm a big fan of headlight relays. And their staffs are also top nothch for customer service and support.
IMHO your own shop / electrical abilities is the primary factor in purchasing a harness or full wiring system. I know guys who think nothing about ripping down transmissions with no fear, but wiring projects faint them out. Spaghetti wiring or fear of cooking the whole ride drive them off those projects unnecessarily.
I have done a few projects with the Factory Fit line and NEVER had a WTF moment and when I did have a color question, their customer service folks got me up and running on the first phone call. If you are replacing a factory installed harness it is as simple as remove old, install the new.
The bottom line will be how much you want to spend BUT remember to factor your time in that equation. We all discount our time to being free. It isn't free. Your time is as valuable as your family and friends and profession dictate. None of us are worthless that is that. So if another harness is cheaper out of the box, but takes twice or three times as long to install when you could have paid a little more upfront but it was plug and play stupid easy and done such as the AAW Factory fit line is the answer is clear.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 16 (permalink) Old Nov 15th, 14, 12:48 PM
Timmy
Hi Dboz
What is wrong with your original Harness ?
I took my Dash Harness out, had like 6 or 7 wires to fix.
Added Classic Auto Air, MSD with Tach lead for my Tachometer, Electric Choke for my Quick Fuel Technology Carb, A lock up switch for my 700R4 Trans and an Indicator Light for when my Converter is in lock up.
On the Forward/ Engine side, Added an Idiot Oil Press Sensor to my Dash Lights (I have the Mech Oil Press Gauge in my Lower Console), Reconfigured my Starter Solenoid for a Mini Starter (Do not use the S Terminal, Choke Lead, Kill Switch/ Hood Lock and bought the MAD front Electrical kit for a Winter project.
I bought more than I needed including the Double Crimp Packard style Terminal crimper for like $70.00.
Have the Wiring Diagrams, Pictures and help from the Internet.
Timmy
french69ssrs is offline
post #9 of 16 (permalink) Old Nov 15th, 14, 01:46 PM
Tim
I bought AAW Factory Fit harnesses to fully rewire my car, cost was ~$1k plus shipping. They were great to deal with. To my way of thinking, it's cheap insurance against 45+ year old wiring that can be brittle, damaged, modified etc.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #10 of 16 (permalink) Old Nov 15th, 14, 04:51 PM
jared
AAW. Fit like a glove and looks factory
jcfcamaro is offline
post #11 of 16 (permalink) Old Nov 15th, 14, 11:44 PM Thread Starter
Dustin
I wanted to thank everyone for their direction. I had planned on keeping the original harness, but the more I dug, the more I found spliced and frayed wires. I will more than likely go with the factory set up because of the time savings.
Thanks again.
dboz67rs is offline
post #12 of 16 (permalink) Old Nov 16th, 14, 12:04 AM
J.R.
I used AAW also and would use it again.
adjudimo is offline
post #13 of 16 (permalink) Old Nov 19th, 14, 04:48 AM
Kim
What about Ron Francis? Is the extra cost for a Ron Francis loom worth it?
kimosabi is offline
post #14 of 16 (permalink) Old Feb 2nd, 15, 06:30 PM
Brent
Just did a 68 RS/SS with American Auto Wire and it worked flawlessly. Highly recommend AAW.
68 RS/SS, 396, 4 Speed
68RS/SS Beast is offline
post #15 of 16 (permalink) Old Feb 3rd, 15, 09:50 AM
painless is that bad? Or is it just not factory looking enough for most?
Deezil is offline
