What goes under the HEI module? (the, apparently, unanswerable questio - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 30th, 14, 01:25 PM Thread Starter
i'm trying to figure out what goes underneath the HEI module?
i'm not concerned about what "should" go underneath----i've heard "white thermal compound"/silicone heat sink/dielectric grease etc.
i want to know what GM put underneath there, from the factory. And, if so, what is the part # if available. If not, what is an aftermarket equivalent?
If you can determine what GM used, from the factory, and can prove it i will make a "sizeable donation" to the site.
Thank you.
puff puff is offline
post #2 of 4 (permalink) Old Nov 30th, 14, 02:45 PM
Re: What goes under the HEI module? (the, apparently, unanswerable que
Auto parts stores should carry heat sink grease. Radio Shack does but, don't use auto,
dielectric or white lithium grease or it'll just run and is not a heat sink.
Grease for a Computer CPU heatsink will also work from a Computer repair store or Amazon.
Note: Your module will be toast if you don't use the proper grease.
http://www.radioshack.com/heat-sink-...g/2761372.html
COPO is offline
post #3 of 4 (permalink) Old Nov 30th, 14, 02:49 PM
It is ,or I should say was, since I can not find the part number for the thermal grease (Not Di-electric) from AC/Delco. I will have to call my buddies garage on Monday and see if any of the 20 oz. tube we had of the grease is still left over to get a part number off of it.
NAPA and Radio Shack sell non-silicone based thermal grease. The usual white stuff is silicone based (cheaper to buy) and it eventually spreads all over the inside of the distributor, which isn't good. The aftermarket tubes of white thermal paste uses for the thermal conducting part of the paste an oxide suspended in the gel, usually of Beryllium-Oxide, Zinc-Oxide or Silver-Oxide, or even Aluminum-Nitrate.
The paste has to be there or you will fry the module. If it died out from excess heat (usually from the motor not the transistors) then it has to be replaced. Also a common problem with white glove restorations is the paint on the intake manifold insulates the HEI from an electrical ground. The factory painted the motor, including the base of the distributor shaft and the exhaust manifold after it was assembled and tested under propane to verify it ran. There fore if you painted fifteen coats of hand rubbed lacquer and color sanded your intake you could cause the motor to stop working or given intermittent ignition problems due to a bad ground.
Big Dave
Larger Dave is online now
post #4 of 4 (permalink) Old Nov 30th, 14, 03:07 PM
Big Dave
I'm often amazed at your knowledge Dave.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
