Inaccurate Tic Toc Tach - Team Camaro Tech
post #1 of 12 (permalink) Old Dec 3rd, 14, 12:28 PM Thread Starter
Hi All,
I have been searching for an answer to the problem that I have been having with my Tach. It is a re-pop tic toc tach and it reads substantially more than my dwell type meter when connected in the same manner which is the tach pick up on the HEI. The meter reads about 550 rpm and in the car it reads 900. I read that there is some sort of adjustment on the original version, but wonder if anyone has experience with a re-pop.
Thanks,
Mr. Fixit
Mr. Fixit is offline
post #2 of 12 (permalink) Old Dec 3rd, 14, 12:48 PM
Re: Inaccurate Tic Toc Tach
Don't always believe a tach/dwell meter. Borrow someone elses tach.
I have 2 meters and both read different rpm's and point dwell. That's why they are so cheap to buy.
COPO is offline
post #3 of 12 (permalink) Old Dec 3rd, 14, 12:54 PM Thread Starter
Thanks Mark. Funny that you mention that because I just came in from trying an old hang on unit that I had. It was pretty close to the Dwell meter at about 575 rpm so it seems that the tic tac tach is in need of something. Just not sure what yet. I will also try another tach that I can borrow from a friend as you have suggested..
Thanks,
Mr. Fixit
post #4 of 12 (permalink) Old Dec 3rd, 14, 01:03 PM
No sure about 69 but the 67 is adjustable.
It has a calibration potentiometer on the circuit board that can be accessed through a hole in the back of the tach. Use a plastic screwdriver from Radio Shack to make the adjustment so nothing gets shorted.
COPO is offline
post #5 of 12 (permalink) Old Dec 3rd, 14, 01:12 PM Thread Starter
Yes, I saw that as well. Mine is a 68. I don't recall seeing any informatio that came along with the new unit when I got it sometime ago. I guess I could pull it out and check to see if it is adjustable if I can't get any specific information.
post #6 of 12 (permalink) Old Dec 3rd, 14, 01:34 PM
69-Pace's Avatar
Are you using points ignition or HEI? HEI requires a filter. https://www.camaros.net/techref/elect...lter/index.htm
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 12 (permalink) Old Dec 3rd, 14, 01:43 PM Thread Starter
It is in HEI distributor. I will do some research about a filter. I imagine some sort of resistor?
post #8 of 12 (permalink) Old Dec 3rd, 14, 01:44 PM Thread Starter
I am responding from my phone, so I am not certain if it is coming through correctly. If you attached a link, I will take a look when I get back. Thanks.
post #9 of 12 (permalink) Old Dec 3rd, 14, 01:47 PM
69-Pace's Avatar
The link is to our reference article to build your own filter. One of these days I will figure out how to put it back on the tech reference menus.
Cheap and easy with parts from Radio Shack. Last time I looked about 6 bucks in parts.
You can buy a filter manufactured by your ignition maker but I would try the DIY one first before parting with cash. It works in 90% of the ignition systems.
69-Pace is offline
post #10 of 12 (permalink) Old Dec 3rd, 14, 05:14 PM Thread Starter
Got it. Thanks
Thanks,
Mr. Fixit
post #11 of 12 (permalink) Old Dec 3rd, 14, 09:42 PM
Chaz
I don't mean to jack this thread but I have a 68 tic toc tach with a mallory unilite ignition. My tach isn't perfectly accurate either and have no filter. Do I need one with the unilite?
68 Camaro
Some mods...
68SSlemans is offline
post #12 of 12 (permalink) Old Dec 4th, 14, 05:04 AM
69-Pace's Avatar
Each HEI system is different in terms of support for older tachometers. But in general if your ignition control box/system doesn't offer a specialized "Tach port" for older tachometers you will need a filter to prevent spits, jumps and general inaccuracies in the read out of the tachometer. Some systems may even damage older tachometers over time without them.
69-Pace is offline
