Remote solenoid switch not activating? - Team Camaro Tech
post #1 of 30 (permalink) Old Dec 15th, 14, 06:37 PM Thread Starter
Chris
Hi, I installed a solenoid switch to address my heat soak issues. I have everything wired up but when I turn the key the starter will not engage. I had a friend turn the key to start position while I put a test light to the solenoid. I have power from the battery to the switch, purple wire (ignition) but not to the main wire to the starter.
I suspected it might be the ground. I added a ground wire on one of the mounting screws to the engine block (block is grounded to frame via ground straps). Still nothing.
How much voltage is needed to activate the solenoid switch?
This is the solenoid I am using - model # SAS-4202.
Any other suggestions I should try? Thanks!
Deevis69 is offline
post #2 of 30 (permalink) Old Dec 16th, 14, 06:28 AM
Re: Remote solenoid switch not activating?
There are several ways to wire a Ferd type solenoid to accomplish what you are trying to do. You didn't say how you wired yours, but I suspect you have it wired incorrectly. Here is one way to wire it - not saying this is the way to wire it, but it's the only diagram I have handy, and it'll work.
I prefer a Bosch style automotive relay. Much smaller, blends in with the background, and doesn't have the F word attached to it. Accomplishes the same thing. You can mount it on one of the heater box studs.
BPOS is offline
post #3 of 30 (permalink) Old Dec 16th, 14, 06:48 AM
Vega$69's Avatar
You need a jumper from the Batt to the S terminal
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 30 (permalink) Old Dec 16th, 14, 08:45 AM Thread Starter
Chris
I purchased and used Mark's set up from MAD. I installed the jumper on the starter. I mounted the solenoid switch close to the battery and extended the purple wire to the front of the car.
Do you think it might not have enough volts to trigger the remote solenoid?
Deevis69 is offline
post #5 of 30 (permalink) Old Dec 16th, 14, 09:12 AM
Is your battery in the trunk?
Describe exactly how you have it wired - every connection. That sort of useful information
Per the link you gave above, "Coil Voltage 6 to 36 VDC". That's the voltage range in which the solenoid works. Hopefully you have at least 6 volts. Still think you miswired something - possibly a dud solenoid though.
BPOS is offline
post #6 of 30 (permalink) Old Dec 16th, 14, 09:14 AM
Vega$69's Avatar
Run from batt to solenoid. Run from opposite site of solenoid to starter. Run purple from switch to solenoid. With the jumper you do not need to run purple back to starter.
The blue wire on mine is from the switch. The purple is for my in tank fuel pump.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #7 of 30 (permalink) Old Dec 16th, 14, 09:18 AM
Yes - purple from ign switch to"S" on the new solenoid.
BPOS is offline
post #8 of 30 (permalink) Old Dec 16th, 14, 10:08 AM Thread Starter
Chris
Here is how I have it wired:
Battery up front and solenoid mounted on the fender (mounting screw ground wire to engine block) > battery to solenoid switch > solenoid switch to starter > jumper on the starter to the starter solenoid (removed purple wire)
Purple wire rerouted and extended to the "S" terminal of the solenoid switch. Although it is not labeled on the switch. The switch has two terminals and I hooked it to the side where the battery connects to the solenoid switch.
I will check the voltage later tonight with a multi-meter. I also have an extra solenoid switch I can try.
Deevis69 is offline
post #9 of 30 (permalink) Old Dec 16th, 14, 10:15 AM
Vega$69's Avatar
With 12v on the purple the solenoid should click pretty loud and with your multi meter you should have continuity (zero resistance) between the lug the battery goes to and the lug from the solenoid to the starter
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 30 (permalink) Old Dec 16th, 14, 11:49 AM
Looking at the specs for the SAS-4202, I see it is connected as in wiring diagram #2 on the spec page. Not quite sure how to interpret that schematic compared to the description in the specifications tab.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #11 of 30 (permalink) Old Dec 16th, 14, 12:38 PM Thread Starter
Chris
@onovakind67 - how did you determine it was wiring diagram #2?
Also, looking at that specifications chart. Which one of those columns means voltage needed to trigger the solenoid?
A. Coil Volts
B. Coil
C. Pickup
Each has a different voltage rating (assuming that # is in volts).
Deevis69 is offline
post #12 of 30 (permalink) Old Dec 16th, 14, 01:32 PM
Vega$69's Avatar
The 1st thing you need to do is verify the contact is closing when you put 12v to the S terminal on the solenoid with the solenoid grounded.
If not the unit is bad or not grounded.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #13 of 30 (permalink) Old Dec 16th, 14, 01:53 PM
A. Coil Volts
B. Coil
C. Pickup
In the wiring diagram column for the relay SAS-4202 I see the number 2.
'Coil volts' is the nominal operating voltage, like 12v for a car.
'Coil' appears to be the coil resistance. Note that the HDI relays have a smaller coil resistance than the C relays, meaning they will pick up at a lower voltage, but dissipate more power in the coil so you can't operate them continuously.
'Pickup' is the voltage at which the relay will pick up. Relays always pick up at a voltage less than the nominal operating voltage.
post #14 of 30 (permalink) Old Dec 16th, 14, 01:54 PM Thread Starter
Chris
@Vega$69 - is that what you meant by "You need a jumper from the Batt to the S terminal"?
Would it be safe for me to just take a wire from the battery and tap the S terminal?
Deevis69 is offline
post #15 of 30 (permalink) Old Dec 16th, 14, 02:12 PM
Vega$69's Avatar
The jumper goes on the starter. If not then the motor will run but the starter will not engage.
Yes you can touch a jumper form the BATT+ to the S term on the solenoid.
Make sure car is in Neutral.
I would disconnect the Cable that goes from Solenoid to Starter and the jump BATT+ to S term and measure voltage on Solenoid lug that the starter cable attaches to. If you get 12V then the issue is at the starter. If no 12V then the Solenoid is bad.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
Tags
heat soak, solenoid, starter
