Alternator wire question - Team Camaro Tech
post #1 of 14 (permalink) Old Jan 16th, 15, 09:56 AM Thread Starter
Ben
Ok I finally got a alternator in that wasn't damaged from factory. I took me a while but anyway, I have a question now. It's a 80 amp proform 1 wire alternator, it says that I need a 10 gauge wire. I can't find my gauge tool to check the size on it right now, before I drive all the way to town, and get new wiring (and gauge) what size is the stock wiring? I bought this one over the 100 amp cause I didn't want to run new wiring. I called the supplier and they said that the 70 amp model runs 10 gauge as well, so I decided to get this one. The alternator replaced was a 60 amp.
Sixty8-camaro is offline
post #2 of 14 (permalink) Old Jan 16th, 15, 10:25 AM
Re: Alternator wire question
You should have a 10 gage wire from the factory as they used the same wire for the biggest and the smallest alternator as that is cheaper than stocking multiple parts that could be installed improperly and has to be paid for with smaller orders and higher business taxes on inventory. (you have top learn to think like a bean counter sometimes to understand the logic of the executive board at Chevrolet).
Though an 80 Amp is still only small to middling in comparison to today's one wire alternators that run up to 230 Amps I would still run an 8 gage wire and upgrade the supply wires to the fuse bus as well if it were my car as I worry about the current carrying capacity of the factory wiring which was based upon the smallest gage to carry the load (has no room for heavier loads being installed such as electric fans, fuel pumps and stereo amps).
Big Dave
Larger Dave is offline
post #3 of 14 (permalink) Old Jan 16th, 15, 10:37 AM
The heavier gauge wire from the alternator (within reason), the better and especially as the length increases. You can accomplish the same thing by running a second wire in parallel next to the existing wire or you can replace it with a single heavier gauge wire.
NH69Z28RS is offline
post #4 of 14 (permalink) Old Jan 16th, 15, 10:38 AM Thread Starter
Ben
I traced my wiring straight to the battery. I before thought it ran to the horn relay but doesn't. It runs direct to battery. So, I should Change that wire to 8 gauge. What about the fuse bus. I'm not following, what is the fuse bus. If it run direct to batt, do you mean add a fuse in between. I'm sorry I'm kinda slow ha ha.
post #5 of 14 (permalink) Old Jan 16th, 15, 10:41 AM Thread Starter
Ben
It is a short wire. Less than a foot long.
post #6 of 14 (permalink) Old Jan 16th, 15, 10:43 AM
Your wire from the alternator should not run to the battery, that's the quick & dirty way to wire it. The correct way is to wire it to the horn relay so it can feed the load point and also charge the battery.
I'll let Dave answer as to the fuse bus he commented on.
post #7 of 14 (permalink) Old Jan 16th, 15, 11:04 AM Thread Starter
Ben
Please explain the horn relay a little more please. Is it a junction point for all power? Why would they bypass it when everything is VERY neatly done and wrapped correctly. Would the battery not charge properly this way? I do have amps and speakers but they are small power. They have there own wires run direct to there own junction block then to battery. Not thru horn relay. I bought this car this way and I'm not sure why the installers would take the time to make everything so nice but not correct. I'm lost really so just wanting to learn.
post #8 of 14 (permalink) Old Jan 16th, 15, 11:33 AM
Probably over simplifying, but....
Alternators have a means of sensing voltage so that the voltage regulator can adjust output voltage to its set-point, usually about 14.2 volts
The farther electicity travels in the elec system, the more voltage drops when compared to the source. Thinner wire also drops more voltage compared to thicker wire. (8ga wire is thicker than 10 ga, and so forth)
A 1 wire alternator senses voltage internally (at the alternator) - the highest voltage the entire system will see is at the big stud on the back of the alternator.
The factory 3 wire system senses voltage real close to the horn relay, which is more centrally located in the system, as a result the entire system will see more voltage compared to the 1 wire.
The horn relay is a major junction, and is the best place to get power for high-draw accessories if you have a 3 wire system. In your case, with a 1 wire and the battery a foot away, the battery (or back of the alternator) is a better choice due to higher voltage there.
BPOS is offline
post #9 of 14 (permalink) Old Jan 16th, 15, 11:45 AM Thread Starter
Ben
Ok thank you so much. Hopefully last question. Should I put a fuse in between the batt and alternator if so what size?
post #10 of 14 (permalink) Old Jan 16th, 15, 01:31 PM
No you normally fuse on a load not the charging device.
The back of the fuse box has a buss bar (a copper or yellow brass piece) that is stamped out of flat metal that distributes the power equally to all of the fuses in the box. If you increase the size wire that goes to the fuse buss you increases the power available inside the box to add fuses or connect an electrical draw to the spades terminals sticking out of it. Electricity can be thought of as being analogous to water. Water flows more freely through a ĺ" inch hose than it does through a Ĺ" inch hose. That is because electrical resistance (Ω ohms) can be thought of as fluid friction. Voltage is analogous water pressure, and Amps as gallons. The buss bar is like a manifold.
It is easier to run power to a single centrally located buss bar and then tap power as needed from it than it is to run wires all over the car going back to the battery as a cable of smaller wires.
Big Dave
post #11 of 14 (permalink) Old Jan 16th, 15, 03:27 PM Thread Starter
Ben
I understand now I got ya. Thanks for explaining it. I just went and ran new 8 gauge wire and started to get everything in place so I can finish it tomorrow. The setup had a 10 gauge wire run to a split pos terminal. I bought a pos connector with two (inputs). One side will be main batt cable and other will be for the alt. Thanks to everyone, now if I can find that washer I dropped for the bolt on the alternator.
post #12 of 14 (permalink) Old Jan 18th, 15, 06:26 PM Thread Starter
Ben
I hooked up the alternator yesterday ran a 8 gauge wire and tested it. It works great thank you guys for the help, I also fixed a thermostat housing leak too, so I finally got to drive it today for only the forth time ever (I hate winter). Thanks for the lesson on alternators and charging.
post #13 of 14 (permalink) Old Jan 19th, 15, 03:57 AM
Congrats on the drive and your education.
This might help you:
Original design alternator is an external regulated and since your configuration is a one-wire alt, apparently the previous owner rewired the Camaro for this configuration. Not a bad thing, just make sure the Charging System works and Power Distribution is supplying the correct power.
post #14 of 14 (permalink) Old Jan 19th, 15, 04:25 PM Thread Starter
Ben
Thank you for the charging diagrams. I haven't gotten a chance to order an assembly manual or wire diagrams so this is a big help.
